1 - 4 of 4 Posts
I purchased the car 3 months ago from a dealership and it appeared to have new from struts installed. After 2 months the sway bar started making contact with the under body ( slight clung sound) whenever the car is driven over slight dips in the road. I have re-centered the sway bar multiple times but within a few days its moved 2+ inches to the left. The right side swaybar link end has moved left 2+ inches. I'm wondering if one of the struts was installed incorrectly putting pressure on the sway bar.
How many miles on the car? I'm thinking the bushings could be worn as well as the swaybar links. I replaced the links and bushings when I did the struts a couple of years ago. Makes a BIG difference in the vehicle's handling.
Car has 167,000 miles. I'm replacing the sway bar links next weekend. I notice that one link has small split in the rubber. On another subject, I starting to hear timing chain rattle from time to time and evaluating whether to replace the engine with low mileage 2.5L or just install a new timing chain. I'm the second owner have records showing previous owner changed oil and other maintenance items on schedule. The car doesn't use oil between changes. I plan on keeping the car for sometime but, definitely should do one or the in the next few months.
Pull the spark plugs to verify the valve cover gasket isn't leaking. If the car isn't burning oil, I see no need to replace the engine unless you're itching to do it for fun.
1 - 4 of 4 Posts
