1 - 12 of 12 Posts
hi all
Been trying to figure out what to do about the mileage in my 2007 Mazda 3 2.3L hatchback. It has ~180000KM on it and has been a bit of a dog running at about 400KM per Fill up if I am lucky. on a bad fill up cycle i may get 320 KM or worse.... This has been a problem for about 18-24 months now with varying results. likely around 60/40 City/Highway ratio. Not a super aggressive driver but live at the top of the cut in North Vancouver, BC and do have to go down that hill a few times a week.
The only mod that I am aware of is K&N Cold air intake (was installed when i got the car used in 2012). Here is what I have done so far:
-MAF sensor wiring: i noted that the MAF wires were getting burned out at the connector and essentially broke on one of the 5 cables. I replaced the connector but did only a crimp job on the existing cable to the new cable/connector. probably about 2 years ago now. used to get tons of engine lights before this change.
-Purge Control Valve : replaced 2 years back.
-Washed out the K&N CAI filter and re-oiled as it was not replaced/cleaned for a long time (don't ask). Probably about 5 months ago when i did it.
-Replaced the K&N CAI drycharger bag as it has a large hole in it. 3 weeks new.
-converted the CAI to a short ram due to poor winter weather and to minimize the change of rain.
-Spark plugs changed out 4 weeks ago.
-ran through a bottle of redline just in case.
-used to have some 225/50/18 rims but swapped to stock 16" winter rims with brand new Michelin cross climate 2's. (2 months old)
-engine light has come on /off periodically at different times but since the wash of the air filter, it seems to have gone away for the most part. When i do get one , it seems to go away after a few days on its own. I did not reset using the on/off method.
I have ordered a brand new CAI Filter as wel as i am not sure if the original has buggered out. also ordered a new gas cap as another step.
What do you think? what else can i do here? not sure what else i can try here....
tks
What code(s)? I'd be interested to see the quality of the crimp connections at the MAF; I think that sensor (as are most all engine sensors) is sensitive to voltage/resistance, and that could be an insidious problem if the repair isn't rock-solid.
With that distance on the odometer, change the Oxygen sensor. Be sure and use a proper tool made for it. The pre-catalyst is the one to target. If that is going bad, it won't trigger a code yet but what it tells the computer based on a wrong view will lead to more fuel being dumped in. If that doesn't fix the issue, you won't be out much money.
Super Moderator
As has already been suggested, lose the L&N CAI and go back to a factory intake (which was also a CAI), clean or replace the MAF, and replace the upstream O2 sensor with either an OEM or Denso sensor (do not use Bosch).
Discussion Starter #7
i did have another look at it today, and saw that the middle of the 5 wires at one end of the crimp was doing really poorly e.g. one or threads of the wire were remaining and the rest of it snapped off. I removed the crimp and re-did it. seems pretty solid and the rest of them appear to be good.
after driving again, i noted the following ECU codes. P0102, P0103, P0113.
not sure if those showed up before my change of the crimped section so will need to drive it a bit more, as i only put in a few KM today.
will see how this goes.
Discussion Starter #8
thanks for the advice here. I will do some investigation to see if it is something i can do, or have to get someone with a lift /risers to help out.
Discussion Starter #9
thanks for the advice. I would love to put the original back but as i purchased the car with the K&N CAI as is, i'm kinda stuck without going to the wreckers yard to get the needed parts again. Not impossible but still a bit of work. when we got the car, it was averaging 9.8-10.0 L /100km (according to the onboard gauge and aware of its limited accuracy) but now heading in the 13.0L end right now..... so guessing it is actually a bit worse.
i'll try the O2 sensor if I have the ability to do so.
As you may know, P0102 and P0103 are consistent with MAF connector fault(s); P0113 is for the IAT (intake air temperature, sensor circuit high input), and it is also consistent with a poor MAF connection.
If you feel confident in the connections now, I'd clear those codes. See if they return, and see if your fuel consumption returns to normal.
I had a very difficult time troubleshooting a similar problem a few years ago. Was getting an intermittent P2188 code. I replaced many of the things you've already replaced with no change. I eventually ran across TSB:01-006/06 that mentioned a poor connection between the terminal and harness wire for the MAF. There is a kit for replacing one the pins on the connector. It ended up fixing it for me.
I think you're on the right track to clean up your MAF wiring. Afterwards, if you still get nagging codes, in particular, P0172, P2178, or P2188 do a google search for TSB:01-006/06 and you'll find everything you need for that repair.
Discussion Starter #12
hi all. after some more work and other weird maintenance, i seem to be back where i started. I will now have to look at just getting the wiring completely redone. I am not sure where the wiring goes on teh car end but getting sick and tired about having this lingering. this sounds like something that I will need to go to a shop to do since I want to put the onus on someone else to 'own' the issue.
TO recap:
-MAF sensor wiring: i noted that the MAF wires were getting burned out at the connector and essentially broke on one of the 5 cables. I replaced the connector + wires as the new connector came with 6 inches of wiring. so essentially crimped the car end of the wiring to the 6 Inches of new ones + connector.
-Changed the MAF sensor itself 2 months back
-Have a K&N CAI + Drycharger. I do not have the original air filter assembly as it came this way when i bought the car used. Replaced both the K&N Filter + Drycharger bag in the past few months.
-converted the CAI to a short ram due to poor winter weather and to minimize the chance of water getting into the system.
-Spark plugs changed out 2 months ago.
-used to have some 225/50/18 rims but swapped to stock 16" winter rims with brand new Michelin cross climate 2's. (3 months old)
-Engine light has not come on and there are no longer any codes.....
-Changed the gas cap with OEM one.
This car is driving me NUTS! with the most recent fill up i have only gotten 110KM with 3/8 tank of gas used.... ridiculous!
1 - 12 of 12 Posts
