I just changed the spark plugs and replaced the ignition coil connector on my Mazda 3 and now it will not idle. I've checked to make sure the connections are being made correctly. And nothing is wired incorrectly it just won't idle anymore. Any ideas on what may be wrong
  • Starts but doesn't stay running?
  • Did you connect an OBD-II scanner to see if there are any pending codes (presuming you'd have mentioned any set codes)?
  • What plugs did you use?
  • Why did you replace the connector, for which cylinder?
