1 - 6 of 6 Posts
I recently replaced the motor and when hooking the wires back up there are 3 connections at the a/ c one is a/c one is cps what is the other one that is connected right there???? Any help been a long week swapping parts out and getting wet in the rain
Discussion Starter · #2 ·
Also I put a 2008 Ford Fusion o I used the ford oil filter and housing will that work the same as the one Mazda had??? Have only ran car for few seconds since I put new motor in want to make sure this part will swap
The Ford Fusion spin on oil filter housing and filter work fine. The 2.0 Mazda's use the same setup, and many people retrofit their 2.3 engines with the spin on filter adapter for easier oil changes. No idea about your other question, every connector should naturally fall into place with its corresponding connector.
1 - 6 of 6 Posts
