I haven't come across anything like that in my limited DIY travels, but certainly believe what you're saying there. Definitely good to know for future reference 👍… You can have good compression but and unacceptable amount leakage. ...
Someone suggested maybe stuck oil control ring on cyl 4 with the lower compression, especially because it went so long without a service before i got it. Going to try a cpl of cheap fixes first that might help a little until i can afford to do more. Its actually decreased oil consumption by almost half now after driving a bit with the new pcv valve in.The fact that he said there was a lot of air coming out of the oil fill is why it sounds like rings. There isn't really another way for that kind of thing to happen. The compression tests look good aside from that one cylinder which, while it tested good, is still down by more than an acceptable amount compaired to the others. A compression test doesn't tell everything either, You can have good compression but and unacceptable amount leakage. He really needs to do a leakdown test as well, I just didn't think to mention it when I made my original post.
Going to pull the plug on cyl 4 and soak with injector cleaner, apparantly works well, then do a oil flush and put in new oil and filter.Someone suggested maybe stuck oil control ring on cyl 4 with the lower compression, especially because it went so long without a service before i got it. Going to try a cpl of cheap fixes first that might help a little until i can afford to do more. Its actually decreased oil consumption by almost half now after driving a bit with the new pcv valve in.
Try to use something designed to break up carbon that doesn't dry too fast. Marvel Mystery Oil is what I would use but I'm not sure if it's available where you live. Whatever you use, let it soak as long as you can, then crank the engine over with the spark plugs out to blow any excess out of the cylinders. Install the spark plugs and coils and start the engine. Then drive the crap out of it. It will smoke a lot when you do this but it's just the cleaner burning off so don't worry about it. I did this with Marvel Mystery Oil on my mother's Equinox (known for sticking rings) and the oil consumption stopped for about three months after the treatment. I need to do it again some time.Going to pull the plug on cyl 4 and soak with injector cleaner, apparantly works well, then do a oil flush and put in new oil and filter.
I did read somewhere to mix it in with a bit of atf lol not sure bout that thoughTry to use something designed to break up carbon that doesn't dry too fast. Marvel Mystery Oil is what I would use but I'm not sure if it's available where you live. Whatever you use, let it soak as long as you can, then crank the engine over with the spark plugs out to blow any excess out of the cylinders. Install the spark plugs and coils and start the engine. Then drive the crap out of it. It will smoke a lot when you do this but it's just the cleaner burning off so don't worry about it. I did this with Marvel Mystery Oil on my mother's Equinox (know for sticking rings) and the oil consumption stopped for about three months after the treatment. I need to do it again some time.
So today i finished doing everything, soaked the pistons, upper engine clean, oil flush and filter change. The oil was as black as diesel oil that has done 20000km. Having said that there was no metalic particles or anything like that which i was worried about. Seems to be running smoother and seems to have a bit more down low. Oil has been filled with gulf western semi syn 10w30.I did read somewhere to mix it in with a bit of atf lol not sure bout that though
Will be interesting to see if this has fixed the issue or at least helped.
That's somewhat normal on vehicles with cartridge style filters. It happens inside spin-on filters too but you can't see it.Thats what the filter looked like after 3000km and had put an extra 10ish ltrs of oil in it to keep it topped up
'Appreciate the updates -- I think many can benefit from this, due to insidious oil consumption of stuck and sludged rings. Would you clarify what mix/products you used for the piston soaking and "upper engine cleaning"? (Did you do something more than pouring something over the pistons? How much did you use each piston?)So today i finished doing everything, soaked the pistons, upper engine clean, oil flush and filter change. The oil was as black as diesel oil that has done 20000km. Having said that there was no metalic particles or anything like that which i was worried about. Seems to be running smoother and seems to have a bit more down low. Oil has been filled with gulf western semi syn 10w30.
1: i pulled all 4 plugs and dribbled a small amount of nulon injector cleaner into each plug hole and left to soak over night. I screwed the plugs back in loose just so nothing can get into the holes over night. The next morning i pulled the plugs and put some rag in the top of each hole and turned the engine over to blow the cleaner out. Then put plugs ect back in.'Appreciate the updates -- I think many can benefit from this, due to insidious oil consumption of stuck and sludged rings. Would you clarify what mix/products you used for the piston soaking and "upper engine cleaning"? (Did you do something more than pouring something over the pistons? How much did you use each piston?)
