1 - 15 of 15 Posts
Is the M3-4 door sedan available yet in the "S" 2.3L engine? When I got to Mazda's website, I cannot even pick the 2.3L when searching inventory.
Thanks.
Kevin
Yea, there are a few people with the Sedan 3s.
Its possible you cant choose the 2.3l because noone has one.
If you're talking about the dealer search, it only gives you a 2.0 option. The 2.3 is available on the market, but for some reason it is not an option on the inventory search. Do the search without an engine choice, and when your results come up, they will show you whether they are the "i" or "s".
HTH
Craig
Mazda search
Yeah, I tried leaving all fields to "ALL" and then sort by engine type. Even went to different parts of the country. Still only the 2.0L shows in their results.
Kevin
Even though it shows 2.0 on the page, as long as you set the trim level to "s", you'll be searching the 2.3L. I just looked up mine on the mazda page and it comes up as a 2.0 with an "S4" trim leveland it's a 2.3L. As long as you're not looking at an "i" it's a 2.3L.
picking s4 trim
The "S4" trim doesn't work either as this is for the sedan 4 door. The results give me cars in my area which I know are only the 2.0L. Mazda needs to edit their configuration to allow for a "S4" trim with 2.3L engine. I have sent their site an e-mail but not sure how responsive they will be.
Kevin
As was mentioned previously DO NOT select an engine option. As long as you selct S4 for your trim option, you are also selecting the 2.3 engine, it's the only engine avaiable in the US with the S trim. All the other option choices work fine on the inventory search.
The same is true of the 5-door hatch. If you select an engine the inventory comes up with no hits.
trim selection
No, the S4 is for the Sedan 4 door vs the Hatchback. But of course for the S4, you can get the "regular" 4 door and then the Sport (the S in S4 is for sedan, not sport).
I did select NO Engine type and I got 6 hits for my local dealer and those are just the M3-4 door option but are not the SPORT editions.
Kevin
Discussion Starter · #10 ·
Mazda site
Yeah, you can select the "S" instead of the "I" but the results come back for both (even though the "S" is selected). The results indicate my local car dealerships as "S" cars but all the cars on their lots are "I"s. Mazda wrote me back indicating they were just building the M3 inventory, etc. and that there might be some problems.
Kevin
Here is the format used by Mazda USA to identify the Mazda3: BBB ED T
the first three characters "BBB" designates the body style:
- M3H: Hatchbach
- M3S: Sedan
the next one or two characters "ED" designates the engine and # of doors
- S5: 2.3L + 5 door
- S4: 2.3L + 4 door
- i: 2.0L (no # of door)
the last character "T" designates the transmission
- A: Automatic transmission
- P: Manual transmission
few examples:
M3H S5 A (MAZDA3 hatchback, 2.3L-5 doors, AT)
M3H S5 P (same but P=manual transmission)
M3S S4 A (MAZDA3 sedan, 2.3l-4 door, AT)
M3S S4 P (again...same in a manual)
M3S i A (Mazda3 sedan, 2.0l-4 door, AT)
M3S i P (yep same in a manual)
The most accurate way to check the body style/engine is by the VIN number
Sedan 2.3L: JM1 BK1230 41 1...
Sedan 2.0L: JM1 BK12F1 41 1...
Hatch 2.3L: JM1 BK1430 41 1...
Discussion Starter · #13 ·
VIN
Bruno,
Don't think the VIN is working like that in USA. Got below from the search on MazdaUSA.
JM1BK123X41138130
which I think, according to search, is a Sedan "i"...
BTW, nice web site on M3.
Kevin
Not sure about the sedans, but my 2.3L Hatch VIN starts with
JM1 BK1434 41 1...
Don't know if this helps the discussion or not.
fearturtle44, and then gt6 notices
JM1 BK1434 41 1...
Thanks all, actually VIN should be like this
Sedan 2.3L: JM1 BK123? 41 1...
Sedan 2.0L: JM1 BK12F? 41 1...
Hatch 2.3L: JM1 BK143? 41 1...
because the last digit of BK???? is a check digit, which depends on later part of the VIN (series). Sorry for the confusion.
1 - 15 of 15 Posts
