1 - 16 of 16 Posts
Thanks. I looked at those threads but did not find a definate answer. I was hoping someone was familiar with this wheel size. I'm pretty sure i read somewhere that the rx8 wheels are 18x8 and were fine on 3's with no rubbing but i was sure of the offset.
For housekeeping sake, you could have posted in the "will this fit" thread.
The rims will fit and 225/40/18 is the tire size you need. Depending on your suspension, you may rub slightly in the front and or rear under extreme cornering or fully loaded.
Oh, and RX-8 rims are +50 keeping them further away from the fenders.
Discussion Starter · #7 ·
Thanks Daniel. Will that offset look odd on the car or will it look good. If RX8 wheels are +50 will these sit further out or more in. I apologize for the questions but I'm not to familiar on how offset works.
My rims are exactly the same fitment, I'm lowered and I run 215/45s with no rubbing. You should also be fine with 225/40s as they are about the same outer diameter; I have enough clearance with mine that I don't think the slightly wider tires would rub either.
[quote author=ismail_alikhan link=topic=135112.msg2909530#msg2909530 date=1233690089]
I am getting some RX-8 Wheels their coming with 225/45/18 tires, will these rub? once again on OEM rx8 wheels....what is the ideal size, and what is the thinnest tire I can put on, would 215's fit?
You want 225/40/18 tires.
Thanks Dan....I will let my tire guy(my uncle) ...lol....know....man ur car looks sick...its amazing....lol..and the mods uve gotten sick...how hard was it to put on the ms3 exhaust? and did u buy the exhaust new? or was it a used one u picked up?
[quote author=ismail_alikhan link=topic=135112.msg2918510#msg2918510 date=1233965984]
Thank you! I've spent a lot of time and way too much money on it. My exhaust came off a MS3 with 5 miles on it so it was practically brand new. I have a welder who put it on for $50. Best bang for the buck.
[quote author=danielj link=topic=135112.msg2907798#msg2907798 date=1233630951]
That happens even with the stock wheels and tires...
^wrong...
danialj is correct...
if ur farther from the fender...ull have less rubbing issues..and height does matter too...as more height gives u more clearance
1 - 16 of 16 Posts
