1 - 5 of 5 Posts
I have (2) of these, Both in VERY good condition, I used to have them in my truck and have no use for then any longer. If your interested make me an offer. They are HEAVY and shipping will most likely be fairly expensive. If I remember correctly, the Subs cost me $349 each plus $30 a piece for the boxes
Discussion Starter #2
Dimensions are as follows:
Width 20.25"
Height 15.25"
Depth:
Top 5.25"
Bottom 7.5"
With Sub and Grill installed 8.5" at widest point
Discussion Starter #4
[quote author=Operator link=topic=106512.msg2179848#msg2179848 date=1206462882]
RMS? SVC, DVC? Ohm rating?
Here's what I could find:
Model 5128
12 inch dual voice coil
400 watts RMS (Peak Power 1100 watts)
Recommended Enclosure:
SPL applications: 0.44 cu. ft.
SQ applications 0.62 cu. ft.
Features:
Ultra long throw design for maximum SPL applications and superior sound quality.
The smallest enclosure requirements in the industry yield very high output levels and exceptional accuracy to below 20 Hz.
Rugged die-cast frames support 15-20 lb. magnet assemblies.
Huge laminated foam surrounds and dual spider construction assure accurate voice coil centering with 2” peak excursion.
Dual 2 ohm design optimized for use with Directed class D amplifiers.
8 layer voice coils and massive motors dissipate up to 1200 watts (5128).
Directed’s exclusive Tri-Power rating eliminates guesswork for correct amplifier selection.
Some more specs:
http://www.mmxpress.com/directed/compx_subwoofers.htm
1 - 5 of 5 Posts
