1 - 3 of 3 Posts
I have a friend at work with a 6( I have a 3) and she told me that she changed the battery and her rear driver side window won't work anymore. She can roll it up and down with the switch from the actual door but her driver switch won't work. The only thing she did was the battery swap. She also said that she can't roll down the windows anymore with her Key faub. Any ideas besides a broken switch in the drivers door panel, even though that doesn't explain the Key Faub issue???
Thanks for your help
Justin
That's... strange.
Roll down the windows with the key fob? I'm not sure how that would be possible to start with? The Mazda6 doesn't have that ability that I know of.
Roll the window down all the way then roll it up and hold the up switch for about 5 seconds or so after it is all the way up. This resets the one click up and down so it might also reset the other things. Worth a shot.
If you hold the unlock button on the keyfob for a few seconds the front windows will roll down. Does not work the same to roll them up.
1 - 3 of 3 Posts
