Pittman's ALR Headlight Deoxidizer - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 73 (permalink) Old 02-07-2009, 04:56 PM Thread Starter
icspots's Avatar
I figured I'd start a discussion/gallery here so we could stop threadjacking the Headlight Restoration thread.
Anyway this is about Pittman's ALR headlight deoxidizer. Basically it's a one step wipe on liquid that instantly removes headlight oxidation. If you have surface oxidation then it will remove it immediately and make your lights look fantastically better. If you have a small amount of damage or pitting it will still clean up the headlight, but isn't going to remove the damage.
I used the ALR on my '02 Hyundai Elantra, and on my '05 3. I actually bought the ALR for the Hyundai as it's lights were very cloudy. The ALR removed all of the oxidation in seconds, however there's still some rough patches present where I think the UV coating is starting to wear away which it didn't remove. That said the lights still look way better than they did before. I also tried it on the tail lights just to see if it would make a difference. The tails looked perfectly fine before hand, but after wiping them down they regained a substantial amount of sparkle, so it definitely did something.
While I had everything out I figured I'd try on the Mazda as well even though it looked fine. There was a marked difference before and after on both the headlights and tail lights. The pictures really don't do the product justice, but I highly recommend this to everyone before trying to sand your lights as the ALR doesn't damage/remove the UV coating on the light housings.
Anyway here's some pictures.
Elantra Driver's side Before
Elantra Driver's side After
Mz3 Driver's side Before
Mz3 Driver's side After
Elantra passenger side half/half (second cleaning)
icspots is offline
post #2 of 73 (permalink) Old 02-07-2009, 05:50 PM
Re: Pittman's ALR Headlight Deoxidizer
Finally, pics. Your results are similar to mine. The 3 lenses cleaned up surprisingly well, considering that they looked fine to begin with. I guess it shows that oxidation just doesn't happen overnight.
So far, all thumbs-up for the Pittmans.
3M 50% | RDX stubby | TB ground | Advanced timing | Corksport inserts | M3M shifter bushings | MS3 rear sway | Sumitomo HTR A/S P01
boomhauer is offline
post #3 of 73 (permalink) Old 02-14-2009, 05:14 PM Thread Starter
icspots's Avatar
I got play with this again last night, this time on a friend's 2002 Nissan Sentra. Her lights were almost completely frosted over and had no "clear" parts left. Apparently she'd mentioned it the last time she was a the dealership and they told her it was all on the inside of the lights and she would need to have the inside polished to remove it. Dork.....
Anyway I don't have any pictures of her lights but the difference was ridiculous. Her lights also had the peeling outer coat that my Elantra had, but even with that they're so much more clear now the light output went way way up. Even though that peeling coat was already there under the oxidation it's kind of sad because without the oxidation you can see it plain as day and before it was just hidden. Oh well, we were just living in blissful ignorance before they were clean enough to see it.
icspots is offline
post #4 of 73 (permalink) Old 02-19-2009, 11:00 AM
Send a message via AIM to axelaspeed
so u just put one drop and wipe off? i might buy this to fix my headlights that i tried doing with the wet sand paper method, plastix, and some wax on it
axelaspeed is offline
post #5 of 73 (permalink) Old 02-19-2009, 12:52 PM Thread Starter
icspots's Avatar
[quote author=AxelaSpeed link=topic=135635.msg2947201#msg2947201 date=1235059236]
Yup, just dab on the cloth and rub the housing. There are some good videos on youtube. Bear in mind if you have physical damage it won't do anything..... if it's oxidation you're golden.
icspots is offline
post #6 of 73 (permalink) Old 02-19-2009, 12:57 PM
icspots, I found their list of products a little confusing... which of them is it that you used? Also, I am currently looking for my spare key and if I cannot find it I am really going to rue the day I disregarded your other thread.
Brad
jurgenk is offline
post #7 of 73 (permalink) Old 02-19-2009, 01:12 PM Thread Starter
icspots's Avatar
[quote author=jurgenk link=topic=135635.msg2947594#msg2947594 date=1235066221]
Brad
It's the ALR. I got the 7cc bottle that's about $30. They have several packages with multiple products, so just make sure you're getting the ALR only unless you want other stuff.
lol at your disregard. That said I hope you find your key.
icspots is offline
post #8 of 73 (permalink) Old 02-19-2009, 02:07 PM
[quote author=icspots link=topic=135635.msg2947631#msg2947631 date=1235067156]
If I do not find it I may have to take advantage of your upcoming GB offer on spare keys offered through your key making racket.
jurgenk is offline
post #9 of 73 (permalink) Old 02-19-2009, 03:29 PM
Send a message via AIM to beyonddc
Very interesting ... My 04 Mazda 3 definitely need a good headlight cleaner.
Any idea how long each bottle would last? For example, about how many headlights you can clean with a single bottle.
Do you need to rub it very hard or just do it gently?
Thanks!
-dc-
beyonddc is offline
post #10 of 73 (permalink) Old 02-19-2009, 03:43 PM
I did the lights on our minivan and the level in the bottle moved very little. I don't know - maybe 20 cars?
Only a drop of two is required for each lens. You don't need to rub very hard - the stuff just seems to melt the oxidation.
LinkBack to this Thread: http://www.mazda3forums.com/95-maintenance-care/329099-pittmans-alr-headlight-deoxidizer.html
Maintenance and Care [Archive] - Page 7 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 01-15-2017 03:21 PM
Streetrace.Org ? Vaata teemat - Plastik tulede poleerimine This thread Refback 09-29-2016 02:47 PM
