DIY Oil Change: How-To Guide w/Pics (Updated 10-21-2009) - Page 3 - Mazda3 Forums : The #1 Mazda 3 Forum
post #21 of 412 (permalink) Old 03-31-2004, 10:44 PM
Just bought 2 filters from the dealer today, and the last 3 digits are 302, not the 309 as you have listed..........????????????
BMM3 is offline
post #22 of 412 (permalink) Old 04-11-2004, 08:01 PM
Send a message via MSN to prototype99 Send a message via Yahoo to prototype99
The big plate that you have to take off to get to the filter and drain plug. Is it required for that to be on? Is it just a scrap guard?
Sterling Grey 2009 Ford Escape Limited V6 4WD
Black 2007 Kawasaki Ninja 250
Sunlight Silver 2004 Mazda Axela HB
Solar Yellow 2004 Mazda3 S 4-door (Wife's)
2000 Toyota Camry LE 4-cyl - R.I.P.
prototype99 is offline
post #23 of 412 (permalink) Old 04-12-2004, 12:13 AM Thread Starter
Definitely not required but I think it will mess with aerodynamics if you remove it. It's not too much of a pain to take it off and put it back every oil change.
_________________
Lava Orange 5 Door 5 Speed
raitchison is offline
post #24 of 412 (permalink) Old 04-12-2004, 10:06 AM
I just realized that I posted the following in the "other" non-sticky thread. So I'll just copy it here:
Materials/Tools Used:
Filter: filter and o-ring bought at mazda dealer. didn't get the small o-ring. Will do that next time.
Ramp: Blitz 8000, bought at AutoZone for $20
Wrench: 76mm 14-point oil filter cap wrench
Other: 17mm socket, 6mm hex key - I am only listing the not-so-common tools here.
Special thanks to the OP for his recommendation of the Blitz ramp, the low-profile design really saved the day. Lets me work in safety and comfort. Plenty of room. Other ramps would have hit the bottom lip of the bumper. And plastic never rusts or clangs!!! It's also asphalt-friendly for those of us without concrete driveways.
Just to clarify, the cartridge cap is a 76mm 14-notch. I wasn't sure because there is also 15 notch available. It fit a bit loose, so I guess 74mm may also fit. But 14 notches is it. 15 notch will not fit.
General Observations:
This is without a doubt one of the most frustrating car to do an oil change on, and I've been doing oil changes on family's and friend's cars for over ten years. There is a big hole on the bottom cover which was obviously put in place so that the oil filter can be changed without removing the cover. But it is off by a few inches. Will Mazda offer a free replacement bottom cover when they get this issue corrected? I wonder.
The drain plug on the filter is neat, but it doesn't work very well in getting all the oil out. There is still a lot of dripping going on as you continue to unscrew the cartridge. Granted none of the oil made it onto the floor but I can do that with any oil change, even the ones where the filter is mounted on the side of the engine. I still ended up with a lot of oil on my hands.
Center-pop clips are evil, and I am glad there's only two of them used on the bottom cover. They are evil because once enough pebbles and debri gets into them, the only way to pop the center pin is to break the thing. This won't last beyond a few oil changes. With 7 screws holding the cover on, I won't miss them whey they are gone.
Those two little hooks towards the back on either side of the bottom cover: who's the pea-brain that came up with that design? I give it two oil changes before both get broken off by the monkies at the dealer. Were they really necessary? The cover is already held on by the plastic over-lap tabs.
For anyone who may be looking for another view of changing the oil:
http://www.mazda6tech.com/index.php?...&Itemid=35
It is for a Mazda 6i, but the steps for draining the oil and changing the filter are the same.
Other observations while doing oil change:
*Back of the radiator cover reads "FoMoCo" in fancy lettering.
*Lots of shiny aluminum down there.
*There was a slight amount of grease on the bracket that holds the center drive-shaft. I think this is just grease from the bushing/fitting overflowing because it was purposefully (correctly) overfilled at the factory. It did glisten slightly.
*That chassis heat-shield is shiny!!!
*Bottom of the car is exceptionally clean, almost perfectly flat front to back, even the suspension members are flush, except for the roll bar mounts in the rear.
Have fun guys, don't let the dealer change your oil for this car. There are too many things that can go wrong. They may...
* round the drain bolt nut taking it off
* over-torque and/or strip the drain bolt putting it back on
* strip the hex key hole taking it off or putting it back on
* tear the o-ring putting it on
* leave dirt in the threads of the cartridge cap
* cross-thread the cartridge cap
* round the cartridge cap
* crack the cartridge cap
* crush the filter element
* break the center-pop pins
* break the bottom cover side hook pins
* do any of the other hundreds of things that may damage, scratch, or otherwise piss you off.
Lee
- ABS/SAB/SAC, Moonroof, Changer, Xenon, TPMS - 5 Speed
Adding color to the grayscale seaof cars, one street at a time!!!
LeeLee is offline
post #25 of 412 (permalink) Old 04-20-2004, 10:32 AM
Oil Filter Adapter
I saw from another forum that mazda dealerships now have an adapter that retrofits the cartridge type housing into a regular oil filter that the other 99% of the world uses. They even gave a part number (two acutally, there is a gasket that goes with it) and the hell if I can find it now. It's so frusterating. It was either mazdaworld.org or edmunds.com, but I would put my money on the first one. The price was quoted to be around $15 so this would definately make up from having to go to the dealership every time you wanted to change your own oil and spend $15 on their rip-off parts. If I can find that part number, then I will report it to the mazda3forums.com audience. Someone might want to give thier parts department a call to see if they know about such a thing. Hope it helps!
DJ RMc <- Certified Trance Addict
DJ RMc is offline
post #26 of 412 (permalink) Old 04-20-2004, 10:40 AM Thread Starter
Personally even if such an adapter were available I would stay with the cartridge. Less waste and should be cheaper as they become more common.
_________________
post #27 of 412 (permalink) Old 04-21-2004, 04:28 PM
What is the purpose of removing the cladding from the top of the engine. Does that make something more accessable?
2004 Mazda3 HB Sunlight Silver "Everyday I beat my own personal record for the number of cosecutive days I've stayed alive"
roadbikin is offline
post #28 of 412 (permalink) Old 05-12-2004, 06:46 PM
Just wanted to post my oil change experience... The Filter part number I was given is L321-14-302, not 309. He didn't even have 309 in the system. He said it could have been a filter/o-ring combo at one time. Everything else in the howto is exactly right. Just thought I would let everyone know...
Winning Blue 5dr 5spd - ABS/Xenon/Moonroof
maximum is offline
post #29 of 412 (permalink) Old 06-09-2004, 04:17 PM
Here's yet another guide for changing your oil on the 2.3L motor.
http://www.supercar-engineering.com/...ilC/index.html
I'm not trying to step on anyone's toes (Nice job, Robert!) as there were no guides that I knew of when I took the pictures. *I've had the pictures sitting on my hard drive for a while, and now that I found the time to make the web page, a couple people have already made guides. *Oh well
BTW, does anyone know if the drainplug crush washer is a non-reusable part? *I assume so, but my dealer didn't try to sell me one when I bought my parts *I reused it this time, but if it's a non-replacable part, I'll get a new one next time. *Needless to say I didn't get the part number for the crush washer.
BTW, at my Mazda dealer (which is also the Ford/Lincoln/Mercury dealer), the Ford parts were cheaper than the Mazda parts, though they are exactly the same thing...
--Erik
ErikGross is offline
post #30 of 412 (permalink) Old 06-09-2004, 06:26 PM Thread Starter
Looks good, I like the pictures you took. Though I'm a firm believer in following torque specs.
I did not replace the oil drain plug washer either, in fact I have NEVER replaced the train plug washer in ANY car I've ever changed the oil on. Never had a problem with leaks either.
I've already looked into the Ford parts angle, though apparently the parts for our car are actually more expensive than they are at the Mazda dealer.
_________________
