Max size for 8" door speakers - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 3 (permalink) Old 04-01-2019, 01:49 PM Thread Starter
Has anyone tried the Pioneer TS-MR2040 Marine 8-Inch in the doors for a non-bose system using the bose mounting bracket KD45-66-A61? With the high efficiency it should run fine with stock amp and the 50% more cone area produce better and lower frequency bass without the need of a subwoofer. Just not sure it will clear. Needs 3 inches in back plus 1-5/8 inch in front. Probably less with the grill off.
debs3 is offline
post #2 of 3 (permalink) Old 04-02-2019, 10:45 AM
The Bose speakers are 6". There's no way you're getting an 8 in a door without massive surgery.
theblooms is offline
post #3 of 3 (permalink) Old 04-02-2019, 11:59 AM Thread Starter
The Bose system uses 8" in the door in Gen 3 (years 14-18). Not sure about other years though. The brackets are readily available for about $15 each. My concerns has to do with available depth since the Bose 8" (called 9") is very thin.
debs3 is offline
  Mazda3 Forums : The #1 Mazda 3 Forum > Visual / Audio > 2014+ Electronics Discussion
Inner tie rod nut size 2007 mazda 3 s 2007mazda3 Suspension / Brakes 1 09-04-2018 10:52 AM
Hex Key size question - 2004 mazda 3 S everett-m3s Suspension / Brakes 1 10-07-2017 10:58 PM
2017 size same as 2014? Atracats Mazda3 (Axela) 1 09-18-2017 09:19 AM
What size battery? 1 long cj Maintenance and Care 3 12-13-2016 08:47 AM
