Hstreet -> STF build - Page 3 - Mazda3 Forums : The #1 Mazda 3 Forum
post #21 of 75 (permalink) Old 04-20-2015, 07:39 AM
Originally Posted by Adam3s View Post
so they have bleeder screws for what, grease?
..::z::.. is offline
post #22 of 75 (permalink) Old 04-20-2015, 11:02 AM
mazda3az's Avatar
Yes.
Just went looking, Corksport only offers a 25mm and 28mm bushing size. I think most of us have 32mm?
I cannot find the Hotchkis HD brackets shown anywhere on their site, just the steel ones I already have. ????
Scott Meyers
mazda3az is offline
post #23 of 75 (permalink) Old 04-20-2015, 12:04 PM
32mm bar owners need to use Hotchkis part # 23291250.
post #24 of 75 (permalink) Old 04-20-2015, 01:29 PM Thread Starter
k3v
Where do the mounts break? I added big washers when I booked the mount on
k3v is offline
post #25 of 75 (permalink) Old 04-20-2015, 01:37 PM
They start to deform then fail completely. Those type of brackets are not strong enough for this application, which is why Corksport has done away with them and gone to a heavier duty bracket.
post #26 of 75 (permalink) Old 04-20-2015, 10:17 PM
Maybe not in texas...I never had an issue with my Hotchkis rear bar...but I only ran it for 1 year. But it was a daily driver too...so I dunno...My recommendation...disconnect it when not autocrossing? lol
David Hedderick
2013 MS3
92 Miata - SSM light project
miata_racer is offline
post #27 of 75 (permalink) Old 04-21-2015, 12:09 AM Thread Starter
k3v
Damn, I guess my washers won't help. I have the 28mm Corksport rear bar, and I just ordered new rear bar brackets. I hope they will help eliminate all the noise I'm getting from my rear bar, otherwise maybe I will disconnect the bar when not autocrossing, lol
k3v is offline
post #28 of 75 (permalink) Old 04-21-2015, 12:39 AM
mazda3az's Avatar
RSB Noise
FWIW, I have the 32mm Hotchkis RSB, with the HK factory reinforced brackets. I use the factory MS3 RSB links. I daily drive my car (well, not every day, but often). No issues with the steel HK brackets, but will be upgrading soon just to keep up with Adam and Kevin.
I have *no* RSB noise. None. I do have to retighten the lower nuts a few times a month. I have recently moved the HK bar to the softer of the two positions, with *positive* results .......IMO.
All I think I know.
Scott Meyers
mazda3az is offline
post #29 of 75 (permalink) Old 04-21-2015, 08:19 AM
clemsonmz3's Avatar
Same here. Been using the Hotchkis 32mm bar for 5 years, nearly 100k miles and tons of racing with no signs of damage to the supplied "steel strap" brackets or bushings. I've taken it completely out a couple times to clean it and regrease the bushings (it gets nasty dirty when the grease seeps out around the bushings). My only issue is that the steel screws on the collars are kinda rusted so I don't try to take them off (no need to anyway). I had some noise til I made some spacers like Kevin did. Then for good measure I used TWO nylon locking nuts on each stud. Same method employed to the AWR links. No more noise ever.
Also Danny had a good idea of wrapping the stud with nylon plumbers tape, sounds (pun intended) like it worked for him.
2006 Titanium Gray Mazda3
#23 STF WDCR SCCA
clemsonmz3 is offline
post #30 of 75 (permalink) Old 04-21-2015, 08:23 AM
clemsonmz3's Avatar
Adam just for curiosity's sake, did you break your bracket while you were on R-comps?
#23 STF WDCR SCCA
LinkBack to this Thread: http://www.mazda3forums.com/90-autocross-track-dyno-results/672609-hstreet-stf-build.html
Hstreet -> STF build - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 05-25-2016 10:57 PM
Autocross, Track, and Dyno Results [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-09-2015 10:25 PM
STF to FSP build Thread Adam3s Autocross, Track, and Dyno Results 836 03-14-2018 05:18 PM
dgross7's STF build thread dgross7 Autocross, Track, and Dyno Results 244 11-10-2017 01:15 PM
slow3's '08 Hatch S STF Build slow3 Autocross, Track, and Dyno Results 276 10-12-2015 10:53 AM
Yes Another STF BUILD Bumblebee043 Autocross, Track, and Dyno Results 16 08-13-2013 12:37 PM
STF Build SpeedTheory Autocross, Track, and Dyno Results 7 05-29-2012 09:35 AM
