Hstreet -> STF build - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum
post #11 of 75 (permalink) Old 04-16-2015, 02:27 PM
I'll chime in and say that after a month of installing all three mounts I dont notice the vibes too much anymore. Im sure they softened up, but Ive probably also gotten used to them. Its really personal preference. Im sure there is some extra noise and vibes, but its NOTHING like it was when I first installed them. Pass and rear are AWR 80 duro and a Hardrace hardened rubber trans mount.
All 3 are certainly not required. But the rear mount is definitely the weakest in OEM form and Id consider necessary. My pass mount was broken and leaking everywhere, so it made sense.
FWIW, I drive mine around 60 miles per day.
slow3 is offline
post #12 of 75 (permalink) Old 04-16-2015, 02:48 PM
It depends on the driving situation too. Full mounts with stoplight to stoplight traffic with a/c on = whoah baby, holy vibes. All or mostly highway on the other is much different and much more comfortable for the driver and passenger(s).
I never really experience this "break in" thing and my mounts still feel the same and vibrate the car as much as they did 1.5 years ago when I installed them, which is actually kind of reassuring to me.
post #13 of 75 (permalink) Old 04-16-2015, 03:08 PM
clemsonmz3's Avatar
I had the same experience as Charlie where they either settle a little or I got used to them.
Scott brings up a good point, it's not necessary to replace the pass mount by only doing the rear b/c the failure mode of the pass mount is caused by the stock rear allowing too much fore/aft rotation. So I retract part of my previous statement, the pass mount is not a must have, just the rear one.
2006 Titanium Gray Mazda3
#23 STF WDCR SCCA
clemsonmz3 is offline
post #14 of 75 (permalink) Old 04-16-2015, 03:21 PM
clemsonmz3's Avatar
As far as the trans mount is concerned, I replaced mine out of fear of breaking the stock mount after replacing the other two...weakest link theory. I found that it creates a heck of a whine from the trans. Really bad in 4th in my experience. It took some getting used to (okay honestly it took some getting over it...and a header install!!).
I can definitively say tho that you will notice the performance difference the trans mount makes when you race with it and then take it out. I hated the car when I went back to the stock trans mount, couldn't wait to put it back in. To me there is a benefit to doing all 3 performance-wise. When you only got 140-160 crank hp you want to get as much as possible to the ground not wasted into the chassis.
#23 STF WDCR SCCA
post #15 of 75 (permalink) Old 04-16-2015, 04:00 PM
Definitely this. The difference in throttle response was immediately apparent when I went from full oem to fully poly. It's quite nice. From a performance perspective doing all 3 mounts is the way to go, no question. Doing just the rear mount is a decent compromise for those that want to balance comfort and performance.
post #16 of 75 (permalink) Old 04-16-2015, 11:52 PM Thread Starter
k3v
Great info! I'll just start with the rear mount for now.
I ran delrin motor mounts on my ssm car, which led to a lot of issues. Parts literally broke from all the rattling/vibrations.
k3v is offline
post #17 of 75 (permalink) Old 04-19-2015, 08:14 PM Thread Starter
k3v
Corksport MS3 Rear Sway Bar Install
In the 4.5 years I've had my 3, all I've ever done were oil changes, a couple belts and an alternator. Last weekend, I looked under the rear of the car for the first time. I'm not a huge fan of the rear end links...oh well.
I bought this Corksport MS3 bar from an AZ autoxer before I moved. The price was right I like the zerk fittings on the sway bar brackets.
I knew the MS3 end links were a larger diameter than the MZ3. I wasn't sure if buying a set of MS3 end links would work, so I went the DIY route. I bought metal sleeve from the hardware store, cut it in half, filed it a bit to reduce the outer diameter, drilled some material out of the inside, and then manually pressed them into the softest sway bar hole (right side).
I had an issue with the end link hitting the lower arm, so I added some washers to the side of the end link that mounts to the arm (see the end link on the left side). It provided enough clearance to make me feel comfortable.
Here's a pic of an attached end link with the spacers visible.
Here are some thoughts, after driving around for a week with the bar:
  • I might put a dab of blue loctite on the endlinks, they keep loosening up.
  • It feels good on the street, but I'll need to add some more sleeves for the other holes if I want to go stiffer.
  • I'm going to either paint or plastidip all the exposed metal on the rear bar.
  • I can't wait to replace the front sway bar bushings </sarcasm> At temps of 30 or below, which seems like half the year in Illinois, my car sounds like a big pile of dung. (My interweb research says the bushings are either mushed or need lubing).
k3v is offline
post #18 of 75 (permalink) Old 04-19-2015, 08:34 PM Thread Starter
k3v
I deviated from my original wheel/tire plan. I'm skipping the plan to buy konigs and buying an all season tire for my daily driver 16x6.5" rims.
I'm going to leave the 205/55-16 dunlop zii star specs on my DD rims, and I bought some 16x7.5 sport edition A8 silver wheels with the new Bridgestone RE-71R in a 225/50-16.
Here are a few of the things that led me down this path:
  • Getting my dunlops dismounted and mounted on new wheels, and having the new all seasons mounted on my DD rims is a pain in the ass.
  • Part of my new autox philosophy (for now) is to be able to enjoy my autox car more than just a few days a month. Friends shouldn't let friends commute on crappy tires.
  • I want to drink the Bridgestone kool-aid. Plus they are offering a $70 rebate, twist my arm.
  • I'm bored of black wheels (the only option with the Konigs)
  • Tire Rack > Discount Tire
Camber plates, coil overs, wheels and tires should all arrive this week. I know what I'll be doing next weekend
k3v is offline
post #19 of 75 (permalink) Old 04-19-2015, 09:23 PM
mazda3az's Avatar
Kevin, sharing a few things I think I've learned along the STF path:
Replace now the Corksport rear bar sway bar brackets and bushings. Adam found some nice ones. Those CS brackets will break/deform. *I* also found that
the extreme holes on the three position CS rear bar put the links too close to the LCA. So I pretty much used the middle position. I do use the MS3 rear
links, but the CS bar I used to have came with the spacers you fabricated, so, well done.
And, how new is that CS rear bar? Is it an older model?
Scott Meyers
mazda3az is offline
post #20 of 75 (permalink) Old 04-19-2015, 11:26 PM
Corksport now makes Hotchkis knockoffs. Can't say I blame them, if you can't beat'em, join'em lol.
LinkBack to this Thread: http://www.mazda3forums.com/90-autocross-track-dyno-results/672609-hstreet-stf-build.html
Hstreet -> STF build - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 05-25-2016 11:57 PM
Autocross, Track, and Dyno Results [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-09-2015 11:25 PM
slow3's '08 Hatch S STF Build slow3 Autocross, Track, and Dyno Results 276 10-12-2015 11:53 AM
