STF questions - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum
post #11 of 20 (permalink) Old 01-11-2015, 08:40 PM
fruitloops's Avatar
Just priced out the zIIs.
772$ set of four, $85 shipped to the border.
Gonna buy them in a couple weeks.
It was almost $150 to ship them here, across the border lol. Nothanks.
Bought, not Built
fruitloops is offline
post #12 of 20 (permalink) Old 03-08-2015, 08:02 AM Thread Starter
Does the cat in the header meet the STF requirements with no other cat installed?
slow3 is offline
post #13 of 20 (permalink) Old 03-08-2015, 09:57 AM
Yes it's good. According to the rules if multiple cats (ie: 2 or more) are reduced to just one cat it cannot be more than 6" downstream from the exit of the final OE converter, but you can go upstream all day long and as far as you want.
"Catalytic converters: Any catalytic converters are allowed, but must attach
within 6” (152.4 mm) of the original unit. Multiple catalytic converters
may be replaced by a single unit. The inlet of the single replacement
converter may be located no further downstream than 6” (152.4
mm) along the piping flow path from the original exit of the final OE
converter. The extents of an OE converter are defined by the expansion
chamber in which the catalyst is contained, regardless of placement
within larger exhaust sections. Replacement converters must have a
minimum catalyst density of 100 cells per inch and minimum substrate
length of 3” (76.2 mm)"
post #14 of 20 (permalink) Old 03-08-2015, 10:59 AM Thread Starter
sweet. So I assume the reason you have the race cat is because of your header not having one.
Here is my setup in the post below. Along with the stock header.
http://www.mazda3forums.com/showpost...1&postcount=23
Certainly looks (and sounds..lol) like there is no cat at first glance and I just want to make sure it qualifies before someone says something.
thanks!
slow3 is offline
post #15 of 20 (permalink) Old 03-08-2015, 06:22 PM
Correct.
Nice job on the build so far. Glad you got rid of those Racelands!
post #16 of 20 (permalink) Old 03-09-2015, 09:19 AM Thread Starter
Me too! I knew they were junk, I was just hoping to get through the winter on them. Definitely not the ground controls as it was advertised at the dealer.
slow3 is offline
post #17 of 20 (permalink) Old 03-23-2015, 07:40 AM Thread Starter
What are you guys with hatches doing with all the floor paneling in the cargo area? I had no clue there was that much crap back there until having to pull it apart this past weekend. Aside from the weight, I bet my dog would be much more comfortable in the back with a lower profile cover and may do something to accommodate that as well.
can we legally remove all of the stuff that covers the spare tire?
13.2.F and 13.2.K are fairly open ended rules. The one forward-most portion technically is held in place by 2 Phillips screws, but the rest is not and Id think fall under 13.2.K. Thoughts?
13.2.F. Spare tires, tools, and jacks may be removed. Any fastening hardware
and/or other pieces that can no longer be firmly secured in the absence
of the spare tire may be removed if necessary to ensure compliance
with Section 3.3.3.B.1, Safety Inspection Requirements.
13.2.K. Any item that cannot be held permanently in place by factory-installed
fasteners may be removed.
slow3 is offline
post #18 of 20 (permalink) Old 03-23-2015, 10:24 AM
dgross7's Avatar
Anything that can be removed without tools comes out of my car for events, including my rear headrests.
I'm actually not sure if that is legal, I've noticed other cars with them still on the seats.
dgross7 is offline
post #19 of 20 (permalink) Old 03-23-2015, 10:43 AM
Technically the head rest removal is illegal, if you want to be by the book leave them in.
post #20 of 20 (permalink) Old 03-23-2015, 12:22 PM
dgross7's Avatar
Good to know. I'll pop those back in.
dgross7 is offline
LinkBack to this Thread: http://www.mazda3forums.com/90-autocross-track-dyno-results/659298-stf-questions.html
Autocross, Track, and Dyno Results [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-07-2015 02:31 PM
STF for 2012 Conemasher Autocross, Track, and Dyno Results 17 02-25-2012 11:17 AM
STF Grill EvilGenius 2004-2009 Exterior Modifications 45 07-13-2005 10:42 PM
stf concepts VeLoCiAxe3 2004-2009 Exterior Modifications 0 05-09-2005 04:46 PM
