Threshold braking issues in the 3 - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum
post #11 of 21 (permalink) Old 08-06-2014, 02:31 AM
Originally Posted by philrab View Post
Why not just unplug the ABS module?
Because the rules are very specific about what is allowed and he wants to adhere to those standards. Someone can't just go unplugging whatever they feel like unplugging, particularly when they're a current Solo National champion like the OP is.
post #12 of 21 (permalink) Old 08-06-2014, 09:38 AM
dgross7's Avatar
I wonder if we can side step this issue all together. Does someone want to pull the abs fuse and then do some brake testing to see if this actually fixes the threshold issue?
I have a non-scca event this weekend, I'll pull it and report back. It doesn't happen to me all that often though so I may not see a difference.
dgross7 is offline
post #13 of 21 (permalink) Old 08-06-2014, 10:18 AM
Does anyone know for a fact we can pull the ABS fuse all willy-nilly and be alright?
As you know the car uses the ABS sensors for quite a bit, I'm just wondering if the ABS fuse is only the brake purpose of those sensors.
Otherwise you'll lose power steering along with it as well (which is no bueno on a power rack), and your speedometer, and a few other lesser essentials.
post #14 of 21 (permalink) Old 08-06-2014, 11:31 AM
john_in_the_lbc's Avatar
I don't think defeating the ABS will necessarily disable the brake-assist feature.
it is reading pedal action. read this:
http://auto.howstuffworks.com/car-dr...ke-assist2.htm
https://www.youtube.com/watch?v=I8GA-l3Iwts
It may be adaptive, so if you always slam on the brakes, it might stop kicking in.
My car thread
john_in_the_lbc is offline
post #15 of 21 (permalink) Old 08-06-2014, 09:46 PM Thread Starter
eSienk's Avatar
From my 5 minute research it looks like all but the 2.0 Mazda 3s have Electronic Brake Distribution. This could cause a huge issue if we disable ABS. I've autocrossed an E36 for an entire season without ABS. You know when Miatas are not setup properly and they lock the inside front into everything? Like that but way worse.
eSienk is offline
post #16 of 21 (permalink) Old 08-06-2014, 09:51 PM Thread Starter
eSienk's Avatar
Originally Posted by john_in_the_lbc View Post
Thanks for that video. That's exactly what's going on. Anyone know how to legally defeat EBA?
edit: Found this post but no help
http://www.mazda3forums.com/showthread.php?t=281421
eSienk is offline
post #17 of 21 (permalink) Old 08-06-2014, 11:33 PM
Looks like it's controlled by the ECU - I assume - according to the wiring diagrams.
One section of the ABS control module is handled off to what it refers to a CAN bus to "data link connector-2" which I can only assume is ECU related.
That said, looking into it... this is a sketchy test, but I'm wondering if you ground out or cancel out the connectors on the plug?
The harness that connections has what looks like can be 26 connectors.
There is a wire, BR/G on top, 2nd to far right, IS that data connector.
There should be a wire below it which would be the second wire.. but it doesn't show anything, just says "*" for the wire color.
As a warning, this is coming from an 04 manual, for you have a speed, it may [may] be different.
post #18 of 21 (permalink) Old 08-07-2014, 12:22 PM
Thinking about it on a side note; isn't this the exact same issue the Playboy series Spec Miata guys have?
Isn't that why they tap the brakes before going into a turn to "reset" the system?
If it is the same case, and those guys haven't come up with a solution; I doubt we ever will.
post #19 of 21 (permalink) Old 08-07-2014, 12:51 PM
dgross7's Avatar
I should be careful researching those teams here at the office...
dgross7 is offline
post #20 of 21 (permalink) Old 08-07-2014, 10:28 PM Thread Starter
eSienk's Avatar
Hmmm, so I'm assuming that fools the computer into thinking it's not an emergency stop scenario? I'll try that in the 3 and see if it makes a difference.
eSienk is offline
LinkBack to this Thread: http://www.mazda3forums.com/90-autocross-track-dyno-results/639233-threshold-braking-issues-3-a.html
Threshold braking issues in the 3 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 12-07-2017 03:31 AM
Autocross, Track, and Dyno Results [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-06-2015 02:25 PM
Having vibrating/shaking issues...while braking? FrostyFire Suspension / Brakes 7 03-24-2007 12:17 PM
Interesting Article about Engine Braking vs. normal braking Bartizek Suspension / Brakes 9 06-01-2006 11:14 AM
TPMS Threshold (TSB) davecombs Wheels / Tires 3 10-03-2005 02:00 AM
