Rear camber for auto-x? - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 16 (permalink) Old 03-10-2014, 11:42 AM Thread Starter
What are people typically running for rear camber for auto-x? My car is a 2007MS3, I'm running 18"X8" RX8 wheels and 245/40 Hoosiers.
The front alignment is easy, as much negative camber as I can get, but I'm unsure of how much to run on the rears (never had a car where that was adjustable before). Currently the car has -2 degrees, but I'm playing with increasing that, both for performance and to move the tire further away from the fender lip (car is lowered).
Suggestions?
2007 MS3
1972 Volvo 1800E (Garage Queen) -
2007 Mazda5 - Wife's Car
Stamperman is offline
post #2 of 16 (permalink) Old 03-10-2014, 11:55 AM
JTilus's Avatar
The car currently has -2 degrees front or rear?
On fwd cars, I don't like to run a lot of negative camber in the rear. Somewhere in the -0.5 to -1.5 range is usually okay, but it also depends on the front camber settings.
JTilus is offline
post #3 of 16 (permalink) Old 03-10-2014, 03:01 PM Thread Starter
I'm talking specifically for the rear. The mazdaspeed recommended setting for the rear (with the coil-over kit) is -2. I can't recall what the front is at the moment.
Hoosier calls for a recommended minimum of -2.5 degrees, however I need to understand what that will do to the handling of car before setting it to that amount.
2007 MS3
post #4 of 16 (permalink) Old 03-10-2014, 03:14 PM
dgross7's Avatar
It's really not a simple answer. It depends on so many different factors. Normally tires are more "happy" with a few degrees of negative camber; "happy" tires = more grip. With that said there is a limit, continuously increasing camber does not continually increase grip.
Now that is considering the rear tires by themselves. When you put them with the entire suspension system, especially considering we have fwd vehicles, it gets much mroe complex. With fwd, we can never experience power on oversteer, the gas pedal on a fwd always increases rear wheel grip up to the maximum grip potential, never going past that limit. So the only opportunity to have rotation is entry-oversteer, lift off oversteer, however you want to word it. There are many different ways of achieving this. Decreasing rear wheel grip in general increases oversteer, as does increasing front wheel grip. This can be achieved with sway bars, springs, damping, camber, toe, tire width, the list goes on.
So, can you share more information on your setup?
dgross7 is offline
post #5 of 16 (permalink) Old 03-10-2014, 03:16 PM
Like Justin said, -1 or less is best for the rear. There is no need for more and will make the car tend to push (understeer). The idea with front drive is to maximize front grip, not rear grip.
post #6 of 16 (permalink) Old 03-10-2014, 03:17 PM
JTilus's Avatar
Just curious... where did you find this?
JTilus is offline
post #7 of 16 (permalink) Old 03-11-2014, 12:52 PM
Stickertuner's Avatar
I run oem settings I'm a newb
Stickertuner is offline
post #8 of 16 (permalink) Old 03-11-2014, 01:04 PM Thread Starter
Hoosier tire info sheet, bottom of page #2.
https://www.hoosiertire.com/pdfs/tctR6_A6.pdf
Setup:
Mazdaspeed/KW3 coilovers
18"X8" RX8 Wheels w 245/40-18 Hoosier A6
JBR Rear Bar (new this year)
Whiteline front suspension bushing (stock alignement type - new this year).
Ran it last year a few times with just the coil overs on 18"X7.5" wheels using 215/45 V710s.
Alignment was to the recommended mazdaspeed specs, but with front toe set to zero.
It was OK, but undertired and had push in fast corners, even with the rear shocks sat at full compression stiffness and the fronts turned down.
My plan for alignment this year is as much as neg camber I can get in the front with zero toe and 2.5 neg camber in the rear with the mazdaspeed toe settings.
I ran on old FSP Scirocco for years, but the rears didn't adjust easily (had to use shims).
Planing on running a full local season this year and hopefully beating a couple of local turbo Hondas (close last year). I may run a Match Tour event later in the year, but expect to get killed by the fully prepped cars if I do.
2007 MS3
post #9 of 16 (permalink) Old 03-11-2014, 01:52 PM
JTilus's Avatar
HOOSIER: "For optimum performance the Hoosier P-Metric radial tires require about 3 degrees of camber. There will be a trade off in maximum performance to maximize wear.
Generally, 1/2 degrees less than optimum will result in the best compromise for wear and speed. Less than 2.5 degrees can result in excessive wear on the shoulder junction."
The section in bold is pretty important. You have to choose whether you want better performance or better wear. Hoosier is making VERY generalized recommendations. A 1,600 pound FSP Scirocco built for autox is going to require a much different set up than a 3,600 pound Mustang built for road-racing. They also don't specify front or rear in their camber recommendations.
That said, you could certainly try -2.5 degrees in the rear. However, my experience in various fwd autox cars, has been that -.5 to -1.5 works very well.
JTilus is offline
post #10 of 16 (permalink) Old 03-15-2014, 12:02 AM
I run about 1.6 rear FWIW
David Hedderick
2013 MS3
92 Miata - SSM light project
miata_racer is offline
LinkBack to this Thread: http://www.mazda3forums.com/90-autocross-track-dyno-results/603905-rear-camber-auto-x.html
Rear camber for auto-x? - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 12-06-2017 11:59 PM
Autocross, Track, and Dyno Results [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-06-2015 02:10 PM
Wtb: 08 ms3 rear camber arms camber links aaaslayer Want to Buy | M3F 0 12-26-2012 05:01 PM
Adjusting Rear camber w/spc camber arms shady Suspension / Brakes 15 08-20-2012 01:14 PM
WTB: Sway Bars, Rear Endlinks, Rear Camber Kit beckaztC3 For Sale | M3F 9 10-12-2009 01:07 PM
FS: Mazdaspeed and SPC Rear Camber Links and AWR 70dm Rear Engine Mount phannarith For Sale | M3F 13 09-19-2009 09:24 PM
Rear camber install while replacing rear springs & shocks? saynow20 Suspension / Brakes 3 08-08-2007 01:44 PM
