miata_racer's turrible STF build thread - Page 3 - Mazda3 Forums : The #1 Mazda 3 Forum
 2Likes
post #21 of 259 (permalink) Old 01-31-2014, 10:18 AM
mazda3az's Avatar
12K = ???
So where is the chart to help those of us still metrically illiterate?
Scott Meyers
mazda3az is offline
post #22 of 259 (permalink) Old 01-31-2014, 10:35 AM
Here's a little chart. 12K = 672 lbs/in
http://ipgparts.com/blog/spring-conv...kgmm-to-lbsin/
post #23 of 259 (permalink) Old 01-31-2014, 11:11 AM
mazda3az's Avatar
Thanks. Also found this:
Springs are rated in pounds/inch in the U.S., and Newtons/millimeter elsewhere. I have not seen kilograms/millimeter before, but the conversion will be easy enough.
1 pound = 0.45359237 kilogram
1 inch = 25.4 millimeter
0.45359237/25.4 = 0.0178579673228346
The conversion factor is 0.0178579673228346
So, to convert lb/in to kg/mm you multiply by 0.0179 and to convert kg/mm to lb/in you divide by 0.0179
So my car will be.......... F/R 7/9
Scott Meyers
mazda3az is offline
post #24 of 259 (permalink) Old 02-01-2014, 03:22 AM Thread Starter
Coilovers installed
David Hedderick
2013 MS3
92 Miata - SSM light project
miata_racer is offline
post #25 of 259 (permalink) Old 02-01-2014, 10:03 AM
mazda3az's Avatar
Question Classing Question
Nice looking stuff.... what size rear springs are those, the 2.5", or larger ID?
Regarding the STF Class rules, you are not allowed to modify, cut, or enlarge the top hole on the strut tower.
Your picture seems to indicate that you may have done so.
Scott Meyers
mazda3az is offline
post #26 of 259 (permalink) Old 02-01-2014, 07:34 PM Thread Starter
Ahh...well I"m off to fix that. Good news is I just bent it a bit.
Now to bend it back, remove the adjustment knob and use a regular allen key for adjustment Thanks for catching that Scott. Better now than In September LOL
David Hedderick
2013 MS3
post #27 of 259 (permalink) Old 02-01-2014, 08:06 PM Thread Starter
FIXED!!! So now I need to adjust with a regular 3mm allen wrench. No biggie
David Hedderick
2013 MS3
post #28 of 259 (permalink) Old 02-01-2014, 08:26 PM
mazda3az's Avatar
Nice job, and glad it was only bent. Likely at most local events that your fellow STF competitors would not raise any concerns (depending on how intense they are), but at the larger National events count on it!
Especially if you beat a few of them.
Scott Meyers
mazda3az is offline
post #29 of 259 (permalink) Old 02-01-2014, 09:56 PM
What is that stuff? JB weld?
post #30 of 259 (permalink) Old 02-01-2014, 10:22 PM
eSienk's Avatar
BCs with Swifts? Didn't see that coming. Was expecting a KW variant.
eSienk is offline
LinkBack to this Thread: http://www.mazda3forums.com/90-autocross-track-dyno-results/597234-miata_racers-turrible-stf-build-thread.html
Autocross, Track, and Dyno Results [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-06-2015 03:43 PM
eSienk's STF thread eSienk Autocross, Track, and Dyno Results 28 02-01-2014 03:27 AM
