Ground Control Coilover Kit Install - Page 17 - Mazda3 Forums : The #1 Mazda 3 Forum
post #161 of 175 (permalink) Old 05-12-2014, 07:10 PM
JTilus's Avatar
I have a pair of newer 6" Eibach ERS springs that have one less coil than the older models. So the compressed length is shorter than the older version, which means more travel before coil bind. Another option, might be FCM style bumpstops that would make contact before coil bind. (or at least soften the hit.)
JTilus is offline
post #162 of 175 (permalink) Old 05-12-2014, 07:25 PM
brandini is offline
post #163 of 175 (permalink) Old 05-12-2014, 10:10 PM Thread Starter
mazda3az's Avatar
Thanks! Did not know that these existed. The usable strokes seem to be about the same.
Added to my database.
Scott Meyers
mazda3az is offline
post #164 of 175 (permalink) Old 05-12-2014, 10:35 PM
dgross7's Avatar
Oh. Well that's good to know.
dgross7 is offline
post #165 of 175 (permalink) Old 05-12-2014, 11:24 PM Thread Starter
mazda3az's Avatar
Looking through the Eibach (downloaded) catalog now; could you please share a part number?
Will also research more efficient bump stops. Fat Cat Motorsports......?
And thank you.
Scott Meyers
mazda3az is offline
post #166 of 175 (permalink) Old 05-13-2014, 12:32 AM
JTilus's Avatar
And thank you.
Looks like part #'s haven't changed. Just the design. So the part # should be something like: 0600.250.0XXX (First 4 digits being spring length, next 3 digits are spring diameter, and last 4 digits are spring rate.)
I'm assuming this is a design change, as I have 2 pairs of 6" Eibach ERS springs and the newer ones have one less coil. They are also different rates. So maybe that is part of the reason for the difference?
Yes. Fat Cat Motorsports. Not sure if they have anything direct-fit, but might be worth looking into.
JTilus is offline
post #167 of 175 (permalink) Old 05-13-2014, 02:17 AM Thread Starter
mazda3az's Avatar
Yep.
The number of coils, diameter of the wire, diameter of the actual spring, and spring material all figure into the actual spring rate.
So, no design change at all. They are simply two different rates.
Scott Meyers
mazda3az is offline
post #168 of 175 (permalink) Old 05-13-2014, 09:36 AM
brandini's Avatar
I wasn't sure how they'd compare but one thing to take into account when you run swifts is they weigh less, don't coil bind, and sit flat. Only negative is the minimum height if surpassed can do damage to the spring.
brandini is offline
post #169 of 175 (permalink) Old 05-13-2014, 03:00 PM Thread Starter
mazda3az's Avatar
Spring Rate Adventure
Hey, thanks to everyone who contributed. Learned a little more than before, and now have some new resources I didn't know existed before asking my question.
It became clear, as I suspected, that there is no one correct answer. As with most things "Car", it just......depends.
How much spring is too little, how much is too much......."It depends". Driving style, car setup, course factors....... "It depends".
So, I'll have to find this out for myself. Find "my" answer.
I will be trying the 525# springs in the front this next weekend. That in fact is close to the MINIMUM rate that GC recommends for our cars with their kit. I like the 700# springs on the back, so they stay.
I will report back as to what effect this move has on the car's balance. Fingers crossed.
Scott Meyers
mazda3az is offline
post #170 of 175 (permalink) Old 05-14-2014, 06:02 PM
tigermack's Avatar
We had 7" up front... 6" is too short for racing. We only did it to clear the tall 265/35/18.
and........... I only ran 6" after I retired my MZ3 for autocross so I can tuck the 18x9.5 +45 up front. lol
We have 1000lbs in 6" if you're interested in giving that a shot, you can swap it at the event. Just jack the car up in the middle.
tigermack is offline
LinkBack to this Thread: http://www.mazda3forums.com/90-autocross-track-dyno-results/563498-ground-control-coilover-kit-install.html
Autocross, Track, and Dyno Results [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-06-2015 05:40 PM
BC Coilover Install wastegate13 MazdaSpeed3 Brakes and Suspension 50 01-22-2013 07:26 PM
SOLD: Set of Koni FSD 4045's and Ground Control Front Stops freeflyfreak For Sale | M3F 9 08-13-2011 04:44 PM
Ground-Control coilovers Lawa Suspension / Brakes 6 04-24-2008 02:49 AM
mazdaspeed ground kit and custom exhaust kit pics/clips Fieldbet Modifications 7 08-19-2006 07:12 PM
