Went to the dyno today! - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 7 (permalink) Old 10-17-2013, 06:49 PM Thread Starter
Hi all, just wanted to share with you guys the results of my dyno runs after a local guy did a reflash to my car. I'm impressed!!!
Sorry for the Iphone pics but that's the only thing I had in hand.
base run...
After reflash...
final product...
The torque came down a few points but I'm very very happy overall. Best $200 I've spent on the car so far.
chamaco is offline
post #2 of 7 (permalink) Old 10-17-2013, 09:56 PM
You have a 2.3L with a swapped in manual trans correct? Torque looks good both post and preflash, but pre-flash your peak hp was only 116? That is quite low for a 2.3L with a stick, even bone stock, any idea why? And you supposedly made nearly 155 hp post flash. Hard to believe just a simple tune made nearly 40 whp on a naturally aspirated 3. The numbers just don't add up here. Perhaps you can shed some light on this?
post #3 of 7 (permalink) Old 10-17-2013, 10:14 PM Thread Starter
Yes, my car has the ATX to MTX swap and I'm too very surprise with the numbers post and pre-flash. I have no idea why it was so low given the fact that now has a manual trans and it even was a surprise to the guy doing the flash. It caught us by surprise too how much of an improvement was after the reflash. I don't even have an intake I just have the simple stuff that we all do because is very simple like; crank sensor advance, different exhaust pipe with 2nd cat delete and intake resonator delete with intake hose routed to the front grill.
chamaco is offline
post #4 of 7 (permalink) Old 10-17-2013, 10:36 PM
Very weird. Your car went from very weak to exceptionally strong with just a $200 flash. Also I noticed your torque curve is not really a curve and flat as Kansas up to and past 6,500 rpm with virtually no drop-off. Most V8's would die for that kind of curve, let alone a 4 banger. I hope it's right for your sake, I'm just very skeptical and when it's too good to be true it usually is . I'll be doing a full bolt-on build with CAI, full exhaust with headers and one high flow cat, and a top notch tune and I would be pleased as hell to make 154/139 at the wheels.
post #5 of 7 (permalink) Old 10-17-2013, 10:57 PM Thread Starter
I know, it feels awesome now (obviously I have almost 40hp more now haha). Also forgot to mention the I have that vtcs delete and bsd delete. Anyway, it should be right because I can feel the big difference. From what the guy told me (I was watching the laptop screen while he was working but I don't understand anything of what he was doing) he tweaked the cams timing, the throttle body to open fully sooner and the fuel tables which made it to an air/fuel of 12.25-12.90 according to the wide band.
chamaco is offline
post #6 of 7 (permalink) Old 10-21-2013, 06:56 PM
Stickertuner's Avatar
Where do u live bro.. Who's ur tuner cuz that's flat out amazing gains if they are accurate
Stickertuner is offline
post #7 of 7 (permalink) Old 10-22-2013, 05:53 PM Thread Starter
haha I'm from PR. The guy only promises a 15-20hp gains from the reflash. In my case I'm suspecting that my initial run with the 116hp was so low because of the ECU swap I had to do when swapping the tranny. Like for some reason the ECU was holding back or something since it was working in a different engine, with different sensors and stuff (could something like that even happen? does that make sense?). So, maybe if the car was a factory MTX probably my initial run would've been of 125-130hp + the 15-20hp that the reflash promises is 150-155hp. In that case, the reflash fix the problem of the swap + the 15-20hp can explain that type of gain?
chamaco is offline
LinkBack to this Thread: http://www.mazda3forums.com/90-autocross-track-dyno-results/560426-went-dyno-today.html
Autocross, Track, and Dyno Results [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-06-2015 03:01 PM
Dyno Tuned Today via Cobb AP and Church Automotive nosaccordh22 MazdaSpeed 9 04-19-2011 01:31 AM
Dyno'd my Speed3 today via a Maha Dyno. 339hp/325ft crank 280hp wheel matrix311 MazdaSpeed3 Modifications 38 11-19-2008 12:45 PM
Went to the Dyno today.. SharkDiver MazdaSpeed3 Modifications 20 09-19-2007 06:33 PM
Dyno done today goldfoot Autocross, Track, and Dyno Results 4 02-05-2006 04:12 AM
Dyno'd AEM and BSD today! Got some A/F questions? AzMs3 Modifications 24 02-21-2005 08:06 PM
