5 point harness - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 17 (permalink) Old 09-26-2013, 12:03 PM Thread Starter
arsprod's Avatar
5 point harness
Anyone ever tried putting 5-point harness in mz3 using stock seats? Yeah I know it sounds bizarre but I saw a Civic at the track last weekend that had done it with a harness bar and it looked like it worked well.
arsprod is offline
post #2 of 17 (permalink) Old 09-26-2013, 12:19 PM
philrab's Avatar
Why you should never use five point harnesses without a race seat and a rollbar/cage
It's not recommended for one really good reason; the stock seat is not properly designed to support 5 point harnesses. Without the slots in the seat to locate the harness, there is a possibility that in a severe impact the harness could slip off your shoulders and off the top of the seat, and your face now becomes a crumple zone with the steering wheel. Also bare in mind that the airbag's discharge is calibrated assuming you are suspended by the seatbelt. If you slip free of the belt, your head is going to be moving a whole lot faster and further.
Beyond the belt not holding you, there is also the fact that three point belts are angled into the centerline of the vehicle in case of a roof collapsing during a rollover. In this scenario, your body will be displaced laterally towards the center of the vehicle. You'll still be injured, but more survivable than if the harness held you upright and your forehead has to support the sheetmetal roof as it collapses down on top of you.
Now with modern crash structures, the latter roof collapse if fairly unlikely, but the belts slipping off during impact because no part of the seat is making sure they are properly located is a definite possibility, and I've personally witnessed it.
philrab is offline
post #3 of 17 (permalink) Old 09-26-2013, 12:25 PM Thread Starter
arsprod's Avatar
That might be the most thorough and complete answer I've ever gotten! Thanks, 'nuf said!!
arsprod is offline
post #4 of 17 (permalink) Old 09-26-2013, 12:28 PM
Here's a great tech article with diagrams and reasoning showing why a stock seat cannot safely run a 4 or 5 point harness.
http://www.pirate4x4.com/tech/billav...rness_install/
flatlander937 is offline
post #5 of 17 (permalink) Old 09-26-2013, 12:36 PM Thread Starter
arsprod's Avatar
Excellent - should be a sticky somewhere on the forum! I'll stick with stock belts and CG lock
arsprod is offline
post #6 of 17 (permalink) Old 09-26-2013, 12:37 PM
philrab's Avatar
Actually THISis the most complete answer.
If someone's looking for some of the benefits of a harness (holding you in the seat better) with a stock seat, google CGLock. Autocrossers in stock class use it all the time to prevent the stock seat belt from loosening, which helps pin your butt in the seat better.
philrab is offline
post #7 of 17 (permalink) Old 09-26-2013, 12:47 PM Thread Starter
arsprod's Avatar
Guess you didn't see my response to flatlander first - already using CG Lock, love it! What it doesn't do is hold my upper body flat against the seat which is really nice when running long track stints
arsprod is offline
post #8 of 17 (permalink) Old 09-26-2013, 01:06 PM
Don't do it, you'll compress your back.. (because I've done it before, and it hurts.. bad).
Nor can the stock seat really hold the harness in place meaning it can't work properly.
For your stock seat belt, whenever doing runs or whatever I would suck it in (my chest), pull the seatbelt tight, and then pull hard out so it locks itself in place, and that always worked great for me.
post #9 of 17 (permalink) Old 09-26-2013, 02:03 PM
I'm very happy with my CGlock for autocrossing. In fact, I feel so much more secure in the seat with it that I don't feel right without it anymore. I'm glad you've given up on the idea of a 5-point with a stock seat. It's a shitty way to get hurt or die.
That said, for autocross, I know people who have 4-point harnesses that use the rear seat buckle attachment points. This gives great support to your upper body. It would be a death trap in a track situation or a traffic incident, but if you use it ONLY for autocross it's not bad. It's still smart to have the variety with the breakaway stitching that lets the shoulder straps lengthen under high loads.
But again, just to be clear because this is sort of a life-or-death point: That's ONLY for use in an autocross situation where you're not at risk of high speed collisions with solid objects or other vehicles. This type of harness allows you to leave your stock seatbelts in place, and those are what should be used for regular driving.
ckingsley is offline
post #10 of 17 (permalink) Old 09-26-2013, 03:08 PM
philrab's Avatar
You posted before I could click the button. Brilliant minds think alike.
philrab is offline
LinkBack to this Thread: http://www.mazda3forums.com/90-autocross-track-dyno-results/553490-5-point-harness.html
Autocross, Track, and Dyno Results [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-06-2015 01:13 PM
4 point harness Adam3s Autocross, Track, and Dyno Results 78 05-31-2013 08:09 AM
FS: Speedware harness bar + Sparco 4 point harness for C4 Corvette tigermack General Buy/Sell 5 04-04-2008 06:25 PM
5 point harness in MS3 Ryz Autocross, Track, and Dyno Results 23 01-13-2008 11:30 PM
MOVED: 5 point harness CosmicBlueMS3 MazdaSpeed 0 11-10-2007 11:30 PM
3 point harness? Jebus Interior Modifications 6 03-09-2004 10:28 AM
