Yes Another STF BUILD - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 17 (permalink) Old 08-07-2013, 10:07 PM Thread Starter
Im looking for some help with my STF build this is my current build im in my 3rd full year of autocross running in the top ten in pax at each event but looking to close the gap on the top 3
Suspension
Mazdaspeed Struts
Koni Yellow Shocks
Mazdaspeed rear sway bar
Stock springs
Tires
Bridgestone Potenza 225/45 front on 17x7.5 45 offset
Hankook Ventus v2 concept 215/45 on stock rims
Engine
K&N drop in air filter
looking for some more bang for my buck due to budget car is very well balanced in the dry as soon as the course gets wet there goes the rear end so any help well be well appreciated
Bumblebee043 is offline
post #2 of 17 (permalink) Old 08-08-2013, 12:32 AM
BFG Rivals or Dunlop Z2 tires will help tremendously. Some front Camber plates will help grip. Soften shocks and swaybar in rear in rain and raise tire pressure to lessen contact point and lessen hydroplaning.
I'm so cone-fused!
solort is offline
post #3 of 17 (permalink) Old 08-08-2013, 01:18 PM
PGH Devin's Avatar
SRI or CAI to replace the drop-in filter. Noticeable increase in throttle sensitivity. Cheap upgrade.
PGH Devin is offline
post #4 of 17 (permalink) Old 08-08-2013, 09:22 PM
Suspension
Mazdaspeed Struts
Koni Yellow Shocks
Stock springs
Tires
Engine
Tires. Maybe some slightly lower(not much!) and stiffer springs if you feel the need.
What do you have? 2.3 or 2.0?
This but include the RS3s and maybe RE11As as well as potential tires. Basically get a known good(for heavier cars... light cars can use the Toyos, heavier cars suck with them for example) tire... unless you're running in Nationals, you will not be outdriven by somebody because you chose the wrong tire(provided you choose one that is near the top). I'm probably going to go for RS3s due to cost and most of our auto-x events are in the summer time when it's HOT. Plus that seems to be the tire to have for heavier cars on the lots that the Cincy SCCA runs at.
flatlander937 is offline
post #5 of 17 (permalink) Old 08-08-2013, 10:17 PM
I'd suggest corksport camber plates if the Mazdaspeed ones don't come with plates.
Get much stiffer springs, but don't lower the ride height more than an inch. Maybe even not that much. If you DD the thing go for the highest rate springs you can stomach, maybe start around 400 lb/in.
More rear sway bar, unless you really go balls out with spring rates. You should do springs before selecting a bar, but I'm guessing the tripoint bar will be ideal.
The other suggestions are dead on. Priority one is to get on some real autocross rubber. I'm on Z2s, but rivals, and re-11a are also great. Rs3 are great in high heat but slightly outdated relative to the newer generation. Really though, any real autocross tire will be a big step up from the potenzas.
I agree with the sri suggestion too, and I'd add that if you want to do a full effort STF build, you can also do headers, exhaust, and get a tune.
ckingsley is offline
post #6 of 17 (permalink) Old 08-08-2013, 10:56 PM Thread Starter
The potenzas are re070 off an older sti not sure where to go for the springs and I am leaning towards a sri just dependd on the mony come this spring
post #7 of 17 (permalink) Old 08-08-2013, 11:30 PM
I don't know much about the 070. I think it's a half decent summer tire, right? That's good, but no comparison to a real autocross tire.
Lots of people will sell you springs. If you're on coilovers your springs should be standard diameter, so you can get springs of any rate and length from lots of places. I personally would just call tripoint and describe what you want. They sell hypercoils and will help you choose the right length, rate, etc. They are great engineers and really helpful to talk to.
post #8 of 17 (permalink) Old 08-09-2013, 05:03 PM
color0's Avatar
If STF allows coilover sleeves/perches you should make it a priority to get them on ASAP. It opens up the possibility of swapping springs in the middle of an event should you need to.
Starting spring rates: 400 lbs/in is a measly 7kg/mm lol, you need something above 8k front/6k rear to curb total weight transfer in steady-state cornering. 9k/7k is probably the lower side of good, I know several time-attack Civics on RS3's that need 10k front springs for the tires' grip. And the Tri-Point bar should be perfect for this application like ckingsley said. On the soft setting with 9/7k springs the rear should come out a little and lock back in effortlessly.
color0 is offline
post #9 of 17 (permalink) Old 08-12-2013, 06:26 PM Thread Starter
Sry for taking so long how for should I go with the spring rates considering im going tovstick with the tire offset that I have
post #10 of 17 (permalink) Old 08-12-2013, 06:55 PM
Those civics have an a-arm suspension. We have struts, so our motion ratio is close to 1. A civic with 10k springs is like a 3 with 5k springs. Of course, we need more than they do because of our camber curve.
400 lbs is a compromise rate that will still be relatively comfortable on the street. More would definitely be better.
LinkBack to this Thread: http://www.mazda3forums.com/90-autocross-track-dyno-results/505490-yes-another-stf-build.html
Autocross, Track, and Dyno Results [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-26-2015 01:31 AM
STF to FSP build Thread Adam3s Autocross, Track, and Dyno Results 836 03-14-2018 05:18 PM
dgross7's STF build thread dgross7 Autocross, Track, and Dyno Results 244 11-10-2017 01:15 PM
STF Build SpeedTheory Autocross, Track, and Dyno Results 7 05-29-2012 09:35 AM
STF Grill EvilGenius 2004-2009 Exterior Modifications 45 07-13-2005 09:42 PM
STF concepts.... hate_romania Mazda3 (Axela) 1 07-08-2005 03:19 PM
