dgross7's STF build thread - Page 23 - Mazda3 Forums : The #1 Mazda 3 Forum
post #221 of 245 (permalink) Old 11-13-2015, 05:04 PM Thread Starter
dgross7's Avatar
Originally Posted by miata_racer View Post
the ozone or the revolution? I'm liking the ozone better because of price, but I don't see a support for the pedals?
dgross7 is offline
post #222 of 245 (permalink) Old 11-21-2015, 11:37 PM
Ozone...I've had it about 6 years now and it's great...used to be the only model they had LOL
David Hedderick
2013 MS3
92 Miata - SSM light project
miata_racer is offline
post #223 of 245 (permalink) Old 12-22-2015, 11:39 PM
Originally Posted by dgross7 View Post
newest goodies
Are these the race housings? I'm looking at upgrading my suspension and contemplating going the koni route. Just unsure of what I need and where to find all of the parts
Kenlilley04 is offline
post #224 of 245 (permalink) Old 12-26-2015, 10:06 AM Thread Starter
dgross7's Avatar
Slow3 is selling a set last I checked. He has the housing pictured here. Selling at a steal too.
dgross7 is offline
post #225 of 245 (permalink) Old 04-05-2016, 11:50 PM Thread Starter
dgross7's Avatar
Just out of curiosity, I am trying to resolve the issue of extending the second o2 sensor, good-win racing sells an "extension kit" but it appears the plug may differ slightly between the NC miata's second o2 sensor and mazda3's. I'm sure I could modify the plug to fit as it's the same basic design, but I was curious what others have done.
Here is the good-win racing link: HEADER INSTALLATION LONG extension cord for second O2 Sensor-.for use when installing any header using STOCK MIDPIPE. for MX5
Seems kind of expensive at $50 bucks for some wire and plugs...
Anyway, thoughts on extending the 2nd o2 sensor wires?
dgross7 is offline
post #226 of 245 (permalink) Old 04-06-2016, 12:03 AM Thread Starter
dgross7's Avatar
In other news, I'm flying out to California for the El Toro Pro this weekend, co driving Heinitz's car, should be a nice taste of what those rsx's are capable of!
dgross7 is offline
post #227 of 245 (permalink) Old 04-06-2016, 01:20 AM
I just used the wire provided with the Vibrant header. Cut, twisted, soldered, heat shrink, done. Cost .05 cents in solder and heat shrink tubing.
That should be fun, good luck Danny! I'm getting plenty of practice battling RSX's locally btw
post #228 of 245 (permalink) Old 04-06-2016, 05:40 PM Thread Starter
dgross7's Avatar
I've been told soldering the wires prevents air from moving within the wires, which is needed for the o2 sensor to operate properly. As in it uses the air within the wires as normal and compares?
It honestly sounds odd to me but that's what I was told.
and yes Adam we need to knock these silly rsx's out of here. I'm going behind enemy lines and I'll share any intel I recover.
dgross7 is offline
post #229 of 245 (permalink) Old 04-09-2016, 03:57 AM
Why don't you just drill a hole and weld in a new bung? On my vibrant header the flex pipe I got off of eBay was absolute crap, I just drilled a hole welded the extended bung and boom problem solved. My first O2 sensor is in the header and my second is before the hi flow cat that I bought with my corksport exhaust. I've never had a check engine light because of it.
post #230 of 245 (permalink) Old 04-09-2016, 06:09 PM
Ha ha
Your "odd" instinct is correct. Wires do not conduct air. When in doubt do a little technical reading. http://www.ngk.com.au/oxygen-sensors...en-sensor-work
End result is that NOT soldering wires is what will get you. Poor connections have a higher resistance, and will degrade over time. This will actually throw off the sensor's measurements more and more as time does its work.
- Performance Engineering: ingenuity + details = breaking boundaries -
fallingibeam is offline
LinkBack to this Thread: http://www.mazda3forums.com/90-autocross-track-dyno-results/494338-dgross7s-stf-build-thread.html
dgross7's STF build thread - Page 21 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-22-2017 08:44 AM
dgross7's STF build thread - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-18-2016 07:25 PM
dgross7's STF build thread - Page 23 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 12-27-2015 11:07 AM
Autocross, Track, and Dyno Results [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-11-2015 08:53 PM
~~OVIE's Build Thread!~~ {Awesome Thread of Winsauce} OVIE Forced Induction Discussion 135 03-25-2012 01:41 PM
drumbum897's Build Thread drumbum897 Multimedia / Build Threads 22 10-10-2011 10:14 AM
DAUSTIN's Build Thread daustin Multimedia / Build Threads 38 06-28-2011 11:49 AM
