report on EBC yellowstuff - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 17 (permalink) Old 04-11-2013, 04:04 PM Thread Starter
arsprod's Avatar
Per Adam3s's suggestion, I put EBC yellowstuff pads on my 06 mz3s. I do about 8-12 track days a year and last year ran Akebono Pro-Act/Euro ceramics. They were still good but I had a feeling I could get more from a real track pad.
For the first week while bedding them in they were actually too sticky - they were so touchy I didn't think I'd be able to heel/toe any more. They were also squeaky but there's a note right on the box that says they'll squeal until the "brake in" coating is gone.
This last weekend was first track day of the season at Putnam Park Road Course. The only other difference in the car is the addition of Hotchkiss rear sway bar (only is an understatement).
The brakes were freakin' amazing! In turn one I was braking nearly 100 feet later (from 100+mph) and with the new sway bar could carry a lot more speed. Results - new record time at Putnam cutting over a second from my old record time (1:28.3 vs 1:29.9). More importantly, lap times were consistent as was braking all the way through 30 minute stints. The tires fall off about 20 minutes in so I never had a chance to see if there was any brake fade.
I haven't driven much since Sunday (I bike to work) but I have noticed that they're still squeaking a bit, most likely because I haven't washed off the dust (I'm lazy).
A lot of the muscle cars that run with this group (10/10th Motorsports) run Hawks. Probably because I was thinking about brakes, they're freaking noisy! All in all, it was a great suggestion and I'm thrilled with the upgrade. Thanks to Adam3s!
Aaron in Indy
arsprod is offline
post #2 of 17 (permalink) Old 04-11-2013, 04:13 PM
I just swapped over to EBC slotted and dimpled rotors and EBC Yellows as well.
They certainly made a ton of noise the first few weeks but they're beginning to quiet down.
Haven't had a chance to bed them yet since I'm breaking in the rotors simultaneously, but so far everyone seems to rave about the yellows.
post #3 of 17 (permalink) Old 04-11-2013, 04:30 PM Thread Starter
arsprod's Avatar
I decided to keep the stock rotors and just had them turned. Last year a guy that races a 3speed said these cars are way overbraked - don't bother with rotors or calipers, though I thought seriously about slotteds just because they look so cool!
arsprod is offline
post #4 of 17 (permalink) Old 04-11-2013, 05:00 PM
Oh believe me; this is the first and last time I'll be going anything; maybe slots? doubtful.
These things make sooooo much whirring noises while going down the road; get near a wall and it's obnoxious!
post #5 of 17 (permalink) Old 04-11-2013, 11:41 PM
Aaron, glad to hear you had such positive results! As you noted the Yellows have considerably more bite (hot or cold) than the typical OE replacement pad so less pressure is required on the brake pedal to get the same result. It takes a little while to get used to, but once you do you'll never want to go back. Not only is initial bite much improved, overall braking power is way up as well so braking potential is only limited by how sticky of a tire you are running and the tires mechanical grip with the surface. I noticed that after some time and miles had passed and a few AX events, the pads became as silent as the OE pads and have stayed that way since. Hopefully your experience will be similar.
post #6 of 17 (permalink) Old 04-12-2013, 09:25 AM Thread Starter
arsprod's Avatar
I'm curious to know how long you've had them or guesses about life expectancy.
arsprod is offline
post #7 of 17 (permalink) Old 04-12-2013, 11:32 AM
I've had them on for about a year now and they have seen about 35 autocross events (I did a lot of events last year) and about 30K road miles (lots of regular driving too). They have about 50% life left in them. Before I put them on I was running Hawk HPS pads but wasn't real happy with them (they didn't seem to be any stronger than the OEM pads) and lacked feel and bite.
post #8 of 17 (permalink) Old 04-12-2013, 11:36 AM
I was thinking of getting the green stuff, is it worth the few extra dollars for the yellow?
monkey85 is offline
post #9 of 17 (permalink) Old 04-12-2013, 12:46 PM
I don't have any direct experience with the Green pads, but I have read reviews and I do know they are EBC's entry level street pad (Similar to Hawk HPS pads). If you are expecting a significant improvement/difference from the OEM pads I think you will be disappointed with the Greens. I think EBC really got the formula right with the Yellows and they are a significant leap forward in performance while still remaining street friendly. I would say it's definitely worth it to step up to the yellows if you are looking for an upgrade in performance.
post #10 of 17 (permalink) Old 04-12-2013, 03:05 PM Thread Starter
arsprod's Avatar
Wow, better than I expected
arsprod is offline
LinkBack to this Thread: http://www.mazda3forums.com/90-autocross-track-dyno-results/448881-report-ebc-yellowstuff.html
Autocross, Track, and Dyno Results [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-06-2015 01:12 PM
FS: EBC Yellowstuff brake pads & lightweight battery & REAL Garage Vary Lip (04-06) tigermack For Sale | M3F 11 07-10-2013 04:59 PM
N/A: EBC YellowStuff brake pads, MZ3, F&R. tigermack For Sale | M3F 7 05-31-2011 11:33 PM
Help need carfax report please tlj 3 Mazda3 (Axela) 2 09-18-2007 07:23 PM
Devens Report PZ Autocross, Track, and Dyno Results 24 06-19-2007 09:58 PM
