Flatlander937's 2009 Mazda3i autocross prep/progress thread - Page 3 - Mazda3 Forums : The #1 Mazda 3 Forum
post #21 of 56 (permalink) Old 06-15-2013, 12:32 AM Thread Starter
Originally Posted by Adam3s View Post
Tony, what is happening between between 5.5-6K rpm? The line stops then takes back up again? What is going on with the torque curve? It doesn't look smooth and varied quite a bit from run to run?
I'm not entirely sure... I think it was losing a signal from the wire. Here is a graph vs MPH as indicated by the dynomometer. I had graphs of each printed out should there be an issue comparing the before vs the after on one or the other.
As for the torque curve, I think that has a lot to do with my craptastic worn motor mounts.
Originally Posted by philrab View Post
I did this my my RMM on my old car (before it got totaled.) It definitely helps, and it's a happy medium between suck and poly. That windshield weld is pretty thick stuff even before it sets, so I'd advise anyone using it to have a decent quality caulking gun ( I bent the handle on my cheapy just squirting the stuff into the mount). I believe 4 days to cure is probably conservative, as I gave mine 8 hours and reinstalled it. I did let it set for 24 hours before driving though.
I've noticed a huge difference in the pliability from the 24 hrs after filling the mount, to 48 hrs, and now at 72 hrs(just checked) it is basically solid.
Stock with no filling you can twist the mount by hand with relative ease quite a bit. At 24hrs you can tell only the outside is cured as you can still move the mount pretty easily and watch the stuff stretch. 48 hrs it was noticeably stiffer but when poking the window weld you can tell it's not quite 100% cured... and just checked at the 72hr mark you can feel it's stiff as it will probably get, and doesn't feel gooey at all when pushed with force. You can barely flex it by hand now except when exerting a lot of force on it.
I think 3 days is probably about right. Doubt I will see a difference tomorrow but will report if I feel otherwise.
My main reason is aftermarket mounts = $$ and I don't have the time to bother fabbing my own, though I MIGHT go that route for the RMM since it's very simple to do. I could even just make a big empty "hole", but a sleeve for the bolt to go through, hold it all in place and fill the space with window weld... making it my own bushing. Actually that sounds like a pretty darn neat idea... it will only cost about $20 in materials at very most.
Originally Posted by downhome_grown View Post
i'm going to do the same thing with JB Weld and see how it turns out. i looked on their website and the breaking points are way higher than anything it would see in this application
JB Weld is going to be MESSY as hell... I hate the stuff personally.
Originally Posted by PZ View Post
Are you changing classes - the 'work' you did to he motor mount is not HS legal.
Yes, I've been running in STF since event #2 this year. The ECM tune is not legal for HS either. I look forward to see if it's a really noticeable difference this weekend.
flatlander937 is offline
post #22 of 56 (permalink) Old 06-15-2013, 11:39 AM
philrab's Avatar
Don't recommend JB Weld for this application. You need some flex to allow the engine to align itself, and I'd be concerned about breaking the aluminum portion of the mount.
philrab is offline
post #23 of 56 (permalink) Old 06-16-2013, 11:10 PM Thread Starter
Well, ended up not going to the event today because 1) I was out late last night with friends and just overall tires from the work week and 2) it was an 80% chance of rain/thunderstorms at the event site 1.5hrs away... and it was my first Father's Day and decided I wanted to spend the day with my wife and son instead. Seemed kind of silly to stand around in the rain all day to drive my car for 5 min on Father's Day.
On another note, the motor mount got installed yesterday, feel a few minor vibes at idle, more noticeable with A/C on but overall not bad at all. Nothing like my Jeep was with poly motor and trans mounts. If you have any experience with them, it's about comparable to a PT Cruiser at idle... those pieces of shit vibrate damn near no matter what you try to do
And when I inspected the mount, a small bit of it squirted out from the center. It was not 100% fully cured. If you look to do this, let it cure for a full week IMO. My old mount was actually not broken(surprising I know), just super pliable probably from the age of it. I may just clean it off and fill it as well to have a "spare" and swap out to refix my brand new mount. FWIW it was the front of the mount that stuff squirted out from... which means it was in reverse(engine torques BACKWARDS when going forwards) or it was under engine braking(or bad shifting... ha). It still very stiff and feels 100% better than before. You can tell there is some compliance in the mounts still when launching or taking off, but the level of mushiness is about what you would expect to be for a stock vehicle(any vehicle other than a Mazda3 that is).
And my wonderful wife got me an air compressor for Father's Day... woot woot!
30 gal cast-iron oil-lubed belt driven 110v Campbell Hausfeld was $400 at Tractor Supply. This thing is infinitely quieter than my dad's oil-free compressor ever was. I've basically just done the break-in procedure on the pump and checked the tank over for leaks and ran my 1/4" air ratchet to test it out. Going to change the oil in the pump tomorrow and carry on.
post #24 of 56 (permalink) Old 06-16-2013, 11:17 PM
philrab's Avatar
Happy Father's Day to you sit. This is technically my second, but I spent my first 600 miles away at work.
philrab is offline
post #25 of 56 (permalink) Old 06-17-2013, 01:06 AM
okellyr's Avatar
Ohhh man.... Nice compressor .... The only way IMO... Awesome
Boosted baby....
BOOSTED
okellyr is offline
post #26 of 56 (permalink) Old 06-23-2013, 11:32 PM Thread Starter
Thanks!
Thanks!
Anyway today I finally got the time to wash and wax it... looks gooood again.
Here is a pic of my other mod that should lower my PAX times by about 1 second...
Here are a few pics of my filled motor mount:
And you can see the little bit that squirted out... doh. Let it cure for a full week before using! Luckily this is on the front of the mount, meaning it only loads that side when in reverse or engine braking.
post #27 of 56 (permalink) Old 06-24-2013, 08:15 AM
philrab's Avatar
You're really reminding me about now just how badly I need to polish and wax my car. The paint has so many fine scratches in it, it looks like the PO rubbed it down with a scuff pad.
Oh the joys of the automotive ignorant and automatic car washes.
philrab is offline
post #28 of 56 (permalink) Old 06-24-2013, 01:47 PM Thread Starter
Yeah I'd been putting it off for a while. My front clip looks horrible up close. The hood has a billion little chips too... stupid Mazda paint.
Looks good from 5ft though
post #29 of 56 (permalink) Old 06-26-2013, 12:24 AM
jonorok's Avatar
Lol. This.
My buddy who drives motorcycles told once you wreck or lay your bike down, it's never the same. Also he told me you can never get it looking good again, but you're golden if it passes the 50/50 rule.
If it looks good at 50 feet or 50 miles an hour, no one else will notice.
jonorok is offline
post #30 of 56 (permalink) Old 07-02-2013, 12:37 AM Thread Starter
Autocrossed this last weekend. Did okay. The lot we ran at really sucks with all the loose crap on the surface, it is on a large slope, and the start line began with a right turn up hill... awesome conditions for a low powered open diff FWD car
50/60 in raw time:
http://cincyscca.com/wp-content/uplo...E5/pe5_raw.htm
36/60 in PAX time:
http://cincyscca.com/wp-content/uplo...E5/pe5_pax.htm
Here's the overall results, I'm the only one in my class:
http://cincyscca.com/wp-content/uplo...E5/pe5_fin.htm
I was just short of 2 seconds off of Dave Rudy(the really damn good Mazda3 driver in HS in the Tire Index class)... on a short course like that it is pretty bad.
It was a really damn confusing course as well, I had a DNF first run out as I got lost toward the finish... the next two runs were spent trying not to screw up, then my last few runs I just had a hard time driving the whole course consistently... there was a stupidly tight Chicago box that would punish me every time.
Tires would help too
Will post some GoPro videos whenever I find the free time to upload them.
LinkBack to this Thread: http://www.mazda3forums.com/90-autocross-track-dyno-results/434609-flatlander937s-2009-mazda3i-autocross-prep-progress-thread.html
Flatlander937's 2009 Mazda3i autocross prep/progress thread - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 12-06-2017 10:14 PM
Autocross, Track, and Dyno Results [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-09-2015 05:33 PM
H-Stock Prep and Develop Thread Adam3s Autocross, Track, and Dyno Results 68 12-13-2012 07:36 PM
2009 MAZDA3I TOURING VALUE SEDAN, SHOULD I BUY IT??? 1stmazda!!! Consumer Reviews 2 04-14-2011 08:55 PM
Questions about upgrading my 2009 Mazda3i headunit / cd reciever ElectraGlide 2004-2009 Electronics Discussion 2 09-28-2009 03:06 PM
New 2009 Mazda3i Touring Value Edition Darkfyre I Just Got my Mazda3/MazdaSpeed3! 1 09-29-2008 08:49 PM
Autocross-specific car prep info Joe Cheng Autocross, Track, and Dyno Results 14 05-04-2007 02:31 PM
