STF to FSP build Thread - Page 3 - Mazda3 Forums : The #1 Mazda 3 Forum
 2Likes
post #21 of 837 (permalink) Old 08-22-2012, 10:39 PM
Re: STF build Thread
Yeah. Less grip of streets = need for less spring.
If I were doing an STF build, I'd probably be thinking around 500-600 lbs both front and rear and I'd try to make the stock front bar work. I'd go big rear bar and see where that put me. I don't think the front to rear spring rate ratio has as much to do with balance as a lot of people make out...
2008 3s Sport sedan
ETRSCCA
HS #89
steverife is offline
post #22 of 837 (permalink) Old 08-22-2012, 11:31 PM
Mack is confused, he doesn't know what was on the car. We ran stiffer rear springs in the MS3 because it understeered like a pig compared to the FSP car. Front spring is 50lbs softer on the STX car, it's high relative to the MZ3 because the front was a lot heavier.
For STF, I start out with 550F/600R with no front bar. 225 doesn't generate that much grip.
I don't think you can make it work with the front bar, when we first started with an open diff, it was terrible... You just spend so much time waiting to get on the power.
justint5387 is offline
post #23 of 837 (permalink) Old 08-23-2012, 02:43 AM
tigermack's Avatar
Oh. LOL there you go!
tigermack is offline
post #24 of 837 (permalink) Old 08-23-2012, 10:35 AM
noob question... Where one could buy such high rate springs?
3oomin is offline
post #25 of 837 (permalink) Old 08-23-2012, 10:49 AM Thread Starter
[quote author=3oomin link=topic=212184.msg4263180#msg4263180 date=1345728941]
Right here, just tell them what spring rate and spring length you want and they got it. These springs are 2.5" in diameter so you can't just drop these on your stock style strut. You need to get a conversion kit for your struts or get some coil-overs to use 2.5" springs.
http://www.ground-control-store.com/.../II=918/CA=213
post #26 of 837 (permalink) Old 08-23-2012, 01:19 PM
tigermack's Avatar
http://www.shock-shop.com/
post #27 of 837 (permalink) Old 08-23-2012, 01:52 PM
clemsonmz3's Avatar
^^That's some good prices on Hypercoils. I'm thinking of getting some this off season.
Does anyone know where I could find an open top end and flat bottom end spring to replace my Mazdaspeed Acc. rear springs? <- springs on left side of pic
2006 Titanium Gray Mazda3
#23 STF WDCR SCCA
clemsonmz3 is offline
post #28 of 837 (permalink) Old 08-23-2012, 02:34 PM Thread Starter
[quote author=justint5387 link=topic=212184.msg4263095#msg4263095 date=1345689080]
Justin, are you running no front bar on your car in STX now?
post #29 of 837 (permalink) Old 08-24-2012, 12:30 AM Thread Starter
I think I finally found a quality drop in lowering spring that has the spring rates I want and is also linear.
Made by a company called swift. They make springs for the MS3. They designed for performance, not just looks/drop.
They cost over $300 a set and if you read through their site you can see why.
http://www.swiftsprings.com/products-ss_spec_r.html
Rates are also published online which is rare! They offer springs for the Mazdaspeed3 (which will fit my car) that have a spring rate of 252 lb/in front and rear. Remember stock rates are 150/130 so that is a sizable increase (68% increase in spring stiffness on the front and 93% increase for the rear). Even the stock MS3 rates comparatively soft at 188/171 just to give you an idea. Drop is a bit of a guess, because the MS3 sits slightly lower than my car stock, but my car is also ~300 lbs lighter. They state the drop for the 1st Gen MS3 is 1.0" front and .6" rear.
It will be a good compromise between handling and comfort. This should still be pretty comfortable on the street and not bone jarring stiff. I don't know if I'll be able to tolerate the ride of springs that are 3-5X stiffer than oem on super stiff custom valved shocks for daily use. Sorry.
post #30 of 837 (permalink) Old 08-24-2012, 11:39 AM
I was gonna run Racing Beat Springs on new FSDs for the next season, but now that after reading this thread it seems like this setup would be too soft.
So, with these swift springs, can I just use them with FSDs? or would stiffer springs require better shocks?
I prefer doing it right the first time and not change anything down the road.
3oomin is offline
LinkBack to this Thread: http://www.mazda3forums.com/90-autocross-track-dyno-results/396919-stf-fsp-build-thread.html
STF to FSP build Thread - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 01-22-2018 01:54 PM
STF build Thread - Page 12 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 05-09-2017 12:35 PM
STF build Thread - Page 83 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-10-2016 10:31 AM
STF build Thread - Page 3 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-10-2016 10:31 AM
STF build Thread - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-10-2016 10:31 AM
STF build Thread - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-10-2016 10:31 AM
STF build Thread - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-10-2016 09:43 AM
STF build Thread - Page 3 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-10-2016 09:43 AM
STF build Thread - Page 83 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-10-2016 09:43 AM
STF build Thread - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-10-2016 09:43 AM
STF build Thread - Page 83 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-10-2016 07:59 AM
STF build Thread - Page 3 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-10-2016 07:59 AM
STF build Thread - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-10-2016 07:58 AM
STF build Thread - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-10-2016 07:54 AM
STF build Thread - Page 3 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-09-2016 10:36 PM
STF build Thread - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-09-2016 10:36 PM
STF build Thread - Page 83 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-09-2016 10:36 PM
STF build Thread - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-09-2016 10:36 PM
STF build Thread - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 05-03-2016 07:53 AM
Autocross, Track, and Dyno Results [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-07-2015 04:18 PM
