Delete - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 14 (permalink) Old 10-23-2011, 02:52 AM Thread Starter
Delete
Delete
justint5387 is offline
post #2 of 14 (permalink) Old 10-23-2011, 03:44 AM
tigermack's Avatar
Re: 2012 SCCA STX Auto-x Build
I smoked you, bro.
tigermack is offline
post #3 of 14 (permalink) Old 10-23-2011, 04:07 AM Thread Starter
I didn't cone
post #4 of 14 (permalink) Old 10-23-2011, 04:42 AM
tigermack's Avatar
You moved that cone.
post #5 of 14 (permalink) Old 10-24-2011, 01:55 PM
clemsonmz3's Avatar
Nice write up Justin, thanks for sharing. Couple questions:
What spring rates are you planning on running? Also, why a 255 when the 245 is better in every parameter (tread width, weight, sidewall height, overall diameter)? Did you not have to cut the shock towers for the KMac plates?
2006 Titanium Gray Mazda3
#23 STF WDCR SCCA
clemsonmz3 is offline
post #6 of 14 (permalink) Old 10-24-2011, 02:19 PM
tigermack's Avatar
No cutting strut towers in ST* or *SP classes.
255 is taller so it's slightly better for gearing and it's more grip up front. We did that set up when I was on street tires in my car.
post #7 of 14 (permalink) Old 10-24-2011, 03:11 PM
clemsonmz3's Avatar
[quote author=tigermack link=topic=200031.msg4135866#msg4135866 date=1319480370]
That's why I asked. So the K-Macs fit under the center hole and give you full castor/camber range plus enough shock travel without modifying the tower? How did you accomplish that? Do you have added shock travel with the strut housings?
#23 STF WDCR SCCA
post #8 of 14 (permalink) Old 10-24-2011, 03:13 PM
tigermack's Avatar
No added shock travel. We modified the plates to get more camber. They fit through the center hole with no problems.
post #9 of 14 (permalink) Old 10-25-2011, 01:48 AM Thread Starter
245 is wider than 255??? 255 because its taller, i don't need shorter tires with the ms3 gear ratio
post #10 of 14 (permalink) Old 10-25-2011, 10:08 AM
clemsonmz3's Avatar
Toyo R1R 245/40/17 (9.9&quot has wider tread than the 255/40/17 (9.6&quot. According to Tirerack the 'kook RS3 245/40 is wider too. However, for the RE-11s the 245/40 (9.0&quot is narrower than the 255/40 (9.4&quot. Unfortunately, Tirerack doesn't show sizes for 'hos XS, Star Specs, Cont. DWS.
I agree with the 255 selection now as I wasn't looking at it from the Speed3 perspective. Aiding the gearing by using a taller tire I can understand...forgot that was an issue for the Speed3. Also never heard a Speed3 guy complain about not enough power so I guess the extra pound or two won't even be noticed.
#23 STF WDCR SCCA
LinkBack to this Thread: http://www.mazda3forums.com/90-autocross-track-dyno-results/390229-delete.html
Autocross, Track, and Dyno Results [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-06-2015 01:10 PM
