Autocross and Wheel Hop - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 22 (permalink) Old 02-19-2009, 11:19 AM Thread Starter
I've had my 3 at the past two wet autocrosses and I've been getting some pretty annoying wheel hop (however, it does it in the dry too). I have to let off the throttle and then reapply which is not good for time. Are there any mods that could help in this area? I read it's the motor mounts causing the hop... Thanks!
MrEddie is offline
post #2 of 22 (permalink) Old 02-19-2009, 11:44 AM
Send a message via AIM to chaos4 Send a message via Yahoo to chaos4
Re: Autocross and Wheel Hop
It is mainly the rear (actually called side by Mazda cause the motor sits crossways) mount. A number of companys make stiffer replacements which go a long way to controlling the hop. I personally recommend the SU mount. I have one on my MS3 (same mount fits the MZ3 if you have the 2.3 motor), with about 40,000 miles on it.
Here is the one I recommend:
http://www.streetunit.com/MAZDASPEED..._p/sum3amm.htm
MS CAI, MS CBE, Yellow Racing Coilovers, Hotchkis fonrt and rear sways, Enki RP01 17" with Hoosier R6 (track), AutoPower Race roll bar, GeForce 6 point harness, Cobb mild tune, 278 whp, 310 wtq on a Dyno Dynamics (heart breaker) dyno, Autometer Cobalt boost, oil pressure and oil temp gages. COM SCC 2007, 2008, 2009 and 2011 ST2 Class Champ. Chief of Event Operations, COM SCC
Come race with us!
chaos4 is offline
post #3 of 22 (permalink) Old 02-19-2009, 01:00 PM Thread Starter
Thanks for the quick reply - is the rear mount easy to replace (torque specs?)? I have access to a lift and tools.
MrEddie is offline
post #4 of 22 (permalink) Old 02-19-2009, 01:15 PM
Send a message via AIM to CosmicBlueMS3 Send a message via Yahoo to CosmicBlueMS3
what car and what class are you running in?
rear mount takes you out of stock and into a ST class
1995 Miata R #187 ES
Koni 8611's, Hoosier A6 245/225's, Cobb FSB, Hawk HP Plus, Motul RBF 600, MS cbe, Redline MT-90 and a K&N filter
CosmicBlueMS3 is offline
post #5 of 22 (permalink) Old 02-19-2009, 02:30 PM Thread Starter
I'm running H Stock right now, so I guess I'd be going to ST.
MrEddie is offline
post #6 of 22 (permalink) Old 02-19-2009, 03:23 PM
Even in ST, the volume of metal in the mount can't change, but inserts are legal. I haven't had any wheel hop with inserts, just spin city. But I rarely do bone jarring drag starts anyways.
saitech is offline
post #7 of 22 (permalink) Old 02-19-2009, 03:39 PM
PZ
[quote author=MrEddie link=topic=136737.msg2947671#msg2947671 date=1235068200]
I get little or no wheel hop in my HS car. Before spending money that may or may not fix the problem, you may want to look at your driving style. Smoother application of the throttle (it is not an on/off switch) usually makes the problem go away.
PZ is offline
post #8 of 22 (permalink) Old 02-19-2009, 05:39 PM
+1
I've gotten some wheel hop at Pro Solos and the local drag strip, but never a regular autocross. Make sure your stock mounts are in good shape (both PZ and I have broken one, I believe) and work on being smooth on the throttle.
2008 3s Sport sedan
ETRSCCA
HS #89
steverife is offline
post #9 of 22 (permalink) Old 02-19-2009, 06:59 PM
Banned
[quote author=steverife link=topic=136737.msg2948181#msg2948181 date=1235079580]
+1
Me too!
I also suggest working on throttle modulation. I'm rarely 'right foot in' on launch when autoxing. Practice makes perfect!
SoraNezumi is offline
post #10 of 22 (permalink) Old 02-20-2009, 12:50 AM Thread Starter
So other than the leaking oiling I've heard about, how do you go about checking the motor mounts - visually looking for cracks, wiggle tests, etc? Also, I launch ok, the hops occur when coming out of a sharp turn and applying throttle - I start hopping, so a let off and reapply at a more gentle rate. I had a integra gsr back in the late 90s and it would spin the wheels easy in 1st with hard acceleration but wouldn't really hop too much... Thanks for the replies!
MrEddie is offline
