Autocross FAQ - Page 3 - Mazda3 Forums : The #1 Mazda 3 Forum
post #21 of 134 (permalink) Old 05-16-2008, 12:49 PM
Re: Autocross FAQ
Didn't see them mentioned in the rule book, maybe i will run them and see if i pass tech, i was also wondering if cat back exhausts are allowed? the only mention of exhaust i see (in the scca rulebook and my regional rulebook) is street legal headers.
ericbertrand716238 is offline
post #22 of 134 (permalink) Old 05-16-2008, 01:20 PM Thread Starter
PZ
Re: Autocross FAQ
[quote author=ericbertrand716238 link=topic=87808.msg2319673#msg2319673 date=1210952942]
As a general rule, if it does not say that you can, then you can't. One thing to keep in mind is that almost all of the rules build off of Stock, meaning, if it is legal in stock, it is legal in the higher prep classes.
Because cat-back is allowed in Stock Class, it is allowed in STS as well.
PZ is offline
post #23 of 134 (permalink) Old 05-19-2008, 03:41 PM
Send a message via AIM to cromus
Re: Autocross FAQ
so in order for me to compete in STS instead of STX I would need to go back to stock width tires right? I believe my rx8 wheels are 8" wide and that puts me in STX....
If anyone could check my mods (found in the link in my sig) and verify that if I went back to stock wheels, I could compete in the STS class. Thanks!
cromus is offline
post #24 of 134 (permalink) Old 05-19-2008, 03:48 PM
Re: Autocross FAQ
[quote author=cromus link=topic=87808.msg2325850#msg2325850 date=1211222472]
Yes, but you should get some 7.5' wide wheels for STS.
justint5387 is offline
post #25 of 134 (permalink) Old 05-19-2008, 03:51 PM
Re: Autocross FAQ
thanks!
cromus is offline
post #26 of 134 (permalink) Old 05-24-2008, 11:51 AM
Send a message via AIM to astrob0y
Re: Autocross FAQ
quick question, how do they calculate the final time?
astrob0y is offline
post #27 of 134 (permalink) Old 05-24-2008, 12:32 PM
Re: Autocross FAQ
[quote author=astrob0y link=topic=87808.msg2338961#msg2338961 date=1211640675]
They use timing lights. Ths time starts when you trip the lights at the start and stops when you trip the lights at the finish.
Unless it's a ProSolo, in which case the lights start when the tree goes green.
Silver2.3Touring is offline
post #28 of 134 (permalink) Old 05-24-2008, 12:42 PM Thread Starter
PZ
Re: Autocross FAQ
In autocross the timer starts and stops when you trip the start and finish light beam. Typically, the accuracy is down to .001 seconds.
Usually, the winner of a class is deteremined by your best run, so if you have a bunch of bad runs but manage to pull one out of your a$$ on the last run that is the fastest in the class, you win.
National Tours are a bit different. Each person gets three runs on Saturday and three on Sunday. The best runs from each day are added together to determine class winners.
PZ
PZ is offline
post #29 of 134 (permalink) Old 05-28-2008, 04:30 PM
Re: Autocross FAQ
Times Total
67.921 54.516
67.956
66.457+1
65.683
65.892+1
65.714+1
I know how they keep track of the times but whats the formula to calculate that?
astrob0y is offline
post #30 of 134 (permalink) Old 05-28-2008, 04:47 PM Thread Starter
PZ
Re: Autocross FAQ
[quote author=astrob0y link=topic=87808.msg2347362#msg2347362 date=1212003030]
Times Total
67.921 54.516
67.956
66.457+1
65.683
65.892+1
65.714+1
It looks like the club you ran with is using some sort of factor time. Many clubs do this to 'normalize' times across classes so that in theory if a driver were to drive in two different classes, his final time, after the factor was applied would be the same.
Do you have a link to the results that we can look at. It might help out.
PZ is offline
