04 Mazda3 2.3L Torque to Yield Bolts? - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 9 (permalink) Old 06-25-2016, 01:31 PM Thread Starter
Hello Everyone, I am currently in the process of performing a complete rebuilding of my 2.3L for my 04 mazda 3. I got all my parts back from the machine shop and was gonna start the assembly process. My Haynes manual says I have to replace the Main Bearing Cap beam bolts, but it does say anything else like why to replace them? Do they really need to be replaced? are they torque to yield bolts? I am already $1130 into this project for parts and labor and I really don't want to spend money or wait f0r the parts to come in. Any advice would be appreciated.
Amorrow37 is offline
post #2 of 9 (permalink) Old 06-25-2016, 02:31 PM
bigboi407's Avatar
Ouch......... 2.5 swap would have cost MUCH less and been much more rewarding, Bolts which are recommended to be replaced are because they are Torque to yield, and with such an important role in the engine, reusing them after so much $$ invested would be a very bad idea IMHO
Good luck with the 2.3 rebuild, i was initially going to do that, but once i learned about the 2.5 swap, i was totally into it..... im under $1500 invested in the engine bay including a transmission, clutch kit and all required brand new bolts/washers, i think im around $1300 under the hood
bigboi407 is offline
post #3 of 9 (permalink) Old 06-25-2016, 04:13 PM
Read the torque procedure for the bolts. If it says something like torque to 70Ft-lb + 90 degrees then its torque to yield.
post #4 of 9 (permalink) Old 06-25-2016, 09:27 PM Thread Starter
This is my first Mazda 3 I didn't know the 2.5L swap was a thing. What does the engine come out of and how much more power does it produce?
post #5 of 9 (permalink) Old 06-25-2016, 09:31 PM Thread Starter
It does indeed say 33ft lbs plus 180 degrees. Damn I guess that is one more thing to order. Any idea where I can find a set for a decent price? I didn't see any at rockauto and the local O'rielly can't get them.
post #6 of 9 (permalink) Old 06-26-2016, 10:56 AM
bigboi407's Avatar
Search the forums for the 2.5 swap thread
the 2.5 comes out of a Variety of vehicles, Mercurys, Lincolns, Fords, newer 2.5 mazdas (But theyre more expensive because "Mazda") I specifically used a 2012 Fusion 2.5, the Ecoboost & skyactiv's are not applicable because theyre designed totally different than the other engines
I Too wanted to rebuild the 2.3, but doing the math on the rebuild and factoring the oil consumption problem which can occur, I decided that the 2.5 would be the engine of choice for the way i drive, and NOW i like it so much that i will be building Another 2.5 with a built top end and i plan on getting another 3 to build
post #7 of 9 (permalink) Old 06-26-2016, 02:17 PM Thread Starter
Sadly I didn't know about the Oil consumption issue and I had an engine with less then 40k miles so I wasn't to concerned with checking the Oil. That ended up being my undoing I fried 2 rod bearings. O well. I am already knee deep in this rebuild so I have to finish it because I am in need of a car. But I will look into the swap for the future. Now my only issue is finding the Main Bearing Cap bolts. I guess I have to wait until tomorrow and go to the dealer and pay an arm and a leg for them.
post #8 of 9 (permalink) Old 06-26-2016, 03:42 PM
bigboi407's Avatar
Theres a Dealer that sells on Ebay, QuirkParts, i bought all of my bolts from them and they were reasonably priced, idk if your local dealer would have the bolts in stock, so check around for pricing to get the best deal
post #9 of 9 (permalink) Old 06-26-2016, 06:43 PM
ARP makes a main stud kit. They are around $110 for the set and are re-usable.
https://www.summitracing.com/parts/arp-218-5402
https://www.rallysportdirect.com/par...-main-stud-kit
There are other places to buy them if you search the part number.
  Mazda3 Forums : The #1 Mazda 3 Forum > Misc > Lounge
Throttle body bolts torque specs? turbolover Powertrain 2004-2009 Mazda3 4 11-16-2015 11:41 PM
oil pan bolts torque spec? redhorizon Forced Induction Discussion 1 03-01-2013 02:08 PM
Torque for 20 ATF pan bolts on 2006 2.3L dyazbek Powertrain Technical Information, FAQ's, How-To's 0 09-13-2012 01:43 PM
Torque for rear control arm bolts? 99SEOhio Suspension / Brakes 1 08-19-2012 12:45 AM
2.3 engine bolts torque specification yaap88 Powertrain 2004-2009 Mazda3 5 12-13-2010 04:05 PM
