Fix for map lights not coming on with door opening, but otherwise working. - Mazda3 Forums : The #1 Mazda 3 Forum
 3Likes
  • 2 Post By philrab
  • 1 Post By DarthR8er*
post #1 of 8 (permalink) Old 05-15-2013, 12:40 PM Thread Starter
philrab's Avatar
So, I had this issue last night, and thought I'd post the fix for it. I couldn't get decent pics in my dark driveway, but if someone else needs them I'll try to take some in the daylight.
Symptom: map lights (near the front of the car in the headliner) no longer come on when the doors are opened, but pushing either of the buttons will fire them up, verifying that the bulbs aren't burnt out.
Problem: When you drop the Map Light assembly down out of the headliner (pull really hard straight down, be careful not to break off the edges of the plastic), and look at the backside of the switch. It's a simple plastic post that passes all the way through the assembly, and it has a copper plate on the back side. When the switch is in the DOOR position, it bridges the contacts. If It's in OFF, it opens the circuit. In my case, one of the little plastic fingers on the post that holds the plate broke, and the plate popped off.
The Fix: I was able to epoxy everything back together (the finger back onto the post, and the plate to both fingers for good measure). If you're unable to do that, you could probably solder a piece of wire (or the original plate) between the two contact points to permanently engage the circuit. Your map lights will now ONLY be on the DOOR setting, but otherwise everything will work as normal, just bypassing the switch.
If anyone needs pics, or a diagram, I'll try to post one up, but once you get the assembly out of the head liner it's pretty simple to see what the issue is.
ktmillerpa77 and mazda3.2007 like this.
philrab is offline
post #2 of 8 (permalink) Old 07-02-2013, 01:46 PM Thread Starter
philrab's Avatar
147 views and not a single 'thanks' or 'that's helpful'. Weak.
Am I the only person this ever happened to?
philrab is offline
post #3 of 8 (permalink) Old 07-02-2013, 02:15 PM
john_in_the_lbc's Avatar
yes
My car thread
john_in_the_lbc is offline
post #4 of 8 (permalink) Old 07-02-2013, 03:41 PM
I will say thank you, but haven't had it happen (yet). I don't remove it that often and probably neither do alot of other people which is why this would be a very uncommon issue.
chochobeef is offline
post #5 of 8 (permalink) Old 05-02-2014, 11:31 PM
Problem solved. Thanks!
ttamplin is offline
post #6 of 8 (permalink) Old 05-02-2014, 11:59 PM Thread Starter
philrab's Avatar
Figured I wouldn't be the only one this happened to. Glad it fixed it.
philrab is offline
post #7 of 8 (permalink) Old 09-24-2016, 03:39 PM
DarthR8er*'s Avatar
Just started happening to my 3 a few weeks ago. I'll give your tips a try and hopefully it will fix the problem.
DarthR8er* is offline
post #8 of 8 (permalink) Old 09-27-2016, 06:20 PM
DarthR8er*'s Avatar
Problem fixed. When I popped off the map light cover, the copper plate mentioned fell out. I put it back in as best as I could and now everything works just fine. Thanks again for your help and knowledge fellow members.
philrab likes this.
  Mazda3 Forums : The #1 Mazda 3 Forum > Visual / Audio > Interior Modifications
LinkBack to this Thread: http://www.mazda3forums.com/69-interior-modifications/462281-fix-map-lights-not-coming-door-opening-but-otherwise-working.html
Fix for map lights not coming on with door opening, but otherwise working. - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 10-29-2017 05:43 PM
Interior Modifications [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-06-2015 03:00 AM
How do I remove the map lights on 2010 5 door Sport ? fredbear 2004-2009 Electronics Discussion 14 06-23-2016 09:05 PM
opening fog lights like opening headlights? infearandfaith Exterior Modifications 5 11-02-2011 06:49 PM
2008 Mazda 3 5 door lowbeams/projector lights not working woodc Mazda3 (Axela) 2 11-06-2010 12:17 AM
Why won't my map lights work with my door sills?? PLEASE HELP! LOCK dacaperz Interior Modifications 3 07-04-2009 09:29 AM
5 door Map light passenger side not working deadoralive Interior Modifications 8 04-29-2008 05:36 PM
