LH dip beam failed - need schematic and/or help please - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 1 (permalink) Old 12-28-2016, 11:27 AM Thread Starter
Hi all
I have a UK Mazda 3 Venture 2013 and my left dip has just died.
The bulb is fine - was hot when I checked it so it had been on and a continuity check shows ok.
There is power on the 15A fuses for both sides but there doesn't appear to be any power on the relay - either energising or switched lamp supply.
The relay itself appears ok as I've swapped it with the RH one and it works fine in that position.
Trying to work out where it's getting lost. I guess I could patch the right side to the left to get it working but I'd rather do it properly.
Thanks
Jon
G3NHS is offline
LinkBack to this Thread: http://www.mazda3forums.com/673-2010-2013-exterior-lighting/740650-lh-dip-beam-failed-need-schematic-help-please.html
2010-2013 Exterior Lighting [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 03-13-2017 09:49 AM
2015 Sport GT Brakes failed at 16k miles Delmarksman Introductions 1 11-09-2016 07:26 PM
