weird brake lights - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 2 (permalink) Old 04-03-2016, 07:39 AM Thread Starter
metro's Avatar
Question weird brake lights
hi i have a Mazda 3 bl 2010, and the brake lights stay on. i have checked the fuses the seem to be OK, when i pull the brake light fuses out they stay on but when i pull the interior light fuse they work as normal? any one have any ideas how i might fix this???
Mazda life
metro is offline
post #2 of 2 (permalink) Old 04-03-2016, 09:28 PM
Id start by checking for shorts between the ground side of your break lights (before the break light switch) and the ground for your interior lights. somehow power is bypassing your break switch which turns your break lights on/off when you hit the break pedal, it does this by controlling the ground side of the circuit.
When in doubt, power out!!!!!!
Hurrakane21 is offline
LinkBack to this Thread: http://www.mazda3forums.com/673-2010-2013-exterior-lighting/707170-weird-brake-lights.html
2010-2013 Exterior Lighting [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 05-15-2016 04:42 PM
tail light, brake lights and back-up lights: LED style azazel1024 2004-2009 Exterior Lighting 1 10-19-2011 02:56 PM
Weird brake pads Archenteron86 Suspension / Brakes 4 11-12-2010 10:10 PM
LED 7443 Brake lights / Tail Lights Bulbs - anyone found one that works? igor2 2004-2009 Exterior Lighting 7 05-31-2007 01:44 PM
Weird Brake Feel tylere Stock Issues 2 10-08-2006 09:47 PM
Problems: ABS lights, Brake lights, Airbag lights beyonddc Mazda3 (Axela) 1 01-28-2004 08:25 PM
