HID converstion electrical problem or am I clueless? - Mazda3 Forums : The #1 Mazda 3 Forum
  • 1 Post By tonyzoomzoom
post #1 of 6 (permalink) Old 01-27-2016, 01:28 PM Thread Starter
On Sunday, I installed low-beam H11 4300k HID Headlights with a 35w ballast. I purchased them off of carxenonhidkits.com which seem to have good quality products.
Today, the right marker light did not turn on but the left did. with or without the headlights on too. When using the turn signal the bulb does flash, which indicates the bulb is not burned out. There does not seem to be any lose wiring either. I've heard some kits are hard on the electrical systems of cars, could it be that there is some sort of electrical back-flow preventing the light to turn on? I've also heard that the HID's use less power then halogen.
Is there a test I can do to assess the issue I am having? This is my first conversion, so maybe I'm just being a complete noob.
I could really use some advice,
Cheers.
laraiamazda3 is offline
post #2 of 6 (permalink) Old 01-27-2016, 02:08 PM
The bulb has two separate filaments. One for the parking light and one for the blinker. I suspect it needs replacement.
Another way to check is to swap the two bulbs to see if the issue moves to the other side.
work to live
tonyzoomzoom is offline
post #3 of 6 (permalink) Old 01-27-2016, 08:50 PM
Moderator
Cab0oze's Avatar
+1
Cab0oze is offline
post #4 of 6 (permalink) Old 01-27-2016, 11:41 PM Thread Starter
I didn't realize the bulb had 2 filaments 😳
Thanks for that info!!
I replaced the halogen bulbs back in and both markers are back on?!
Very odd, any ideas?
post #5 of 6 (permalink) Old 01-28-2016, 12:14 AM
At startup the HID system uses a ton of power, hence why there is a ballast. After everything warms up, it only uses a 35w current, the halogen bulbs use 55w.
Machinehead2k5 is offline
post #6 of 6 (permalink) Old 01-28-2016, 12:34 AM
That's weird. I would check your wiring on the HIDs but I believe it's straight plug and play, so it should be pretty straight forward. If wiring looks good, I would then try switching the ballasts from one side to the other to see if the problem follows the ballast.
laraiamazda3 likes this.
work to live
LinkBack to this Thread: http://www.mazda3forums.com/673-2010-2013-exterior-lighting/701385-hid-converstion-electrical-problem-am-i-clueless.html
2010-2013 Exterior Lighting [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 02-03-2016 01:21 PM
Electrical problem halendrummer Powertrain 2004-2009 Mazda3 0 02-03-2013 06:18 PM
Electrical Problem!!?!? lreyes66 MazdaSpeed 11 04-23-2008 09:34 PM
Wanting to purchasing HID converstion kits for Mazda 3 bho15 2004-2009 Exterior Lighting 2 04-16-2007 02:54 AM
MOVED: Wanting to purchasing HID converstion kits for Mazda 3 RB Interior Modifications 0 04-15-2007 11:02 PM
HID vs. HID Converstion Kit italianmaz3 2004-2009 Exterior Lighting 8 01-18-2007 05:29 PM
