HID conversion should I do it? - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 9 (permalink) Old 12-05-2015, 10:17 AM Thread Starter
Hi
I am thinking of doing an HID conversion on my low berms and my fog lights.
Is it safe on the OEM components?
What should I look for in a good quality conversion kit?
Recommendations on kits and parts?
Sent from my SM-G900W8 using Tapatalk
Jordan 100
2012 Mazda 3 Sport
Jordan1200 is offline
post #2 of 9 (permalink) Old 12-06-2015, 09:13 AM
ultimica06's Avatar
Good quality HID Kit...I Highly recommend the Morimoto HID Kit in the 5500k color from www.retrofitsource.com
I wouldnt put HIDs in foglights....but people do it....
Might have to Re-Aim the lights after installing a HID Kit too.
ultimica06 is offline
post #3 of 9 (permalink) Old 12-06-2015, 09:56 AM
Exactly as Ultimica said. The Morimoto HID kit is the best of the best. I've got it on my 3 and it's so far superior to the factory halogens. Definitely recommend this set.
..::z::.. is offline
post #4 of 9 (permalink) Old 12-06-2015, 07:20 PM
Morgannec's Avatar
on my 07 i ran hids in the lows, fogs, and high beams. the low beam projectors suck balls and i really recommend upgrading projectors because really all you are doing is throwing an hid bulb into a halogen projector. retrofits are very easy, but there's not a terrible consequence for doing so if you are on a budget.. there is also nothing wrong with putting them in your fogs, just dont use 55w kits and stay with the 35w kits
Morgannec is offline
post #5 of 9 (permalink) Old 12-08-2015, 02:56 PM Thread Starter
I have seen a few different recommendations, I own a 2012 mazda 3 hatchback with the highbeems on the i side. Do i need to run a direct connection to the battery? What are the pros and cons of this setup?
Do I need a CANBUS ballast?
I have heard that an HID conversion is hard on electrical components. Is there any merit to this and if so please explain. Thanks again.
Sent from my SM-T700 using Tapatalk
Jordan 100
2012 Mazda 3 Sport
post #6 of 9 (permalink) Old 12-13-2015, 12:31 PM Thread Starter
There is a forum for HID stuff called HID planet the folks on there said even though i have projector housings they are for Halogen bulbs snd differ slightly from true HID projector housings. It was suggested that do a retrofit of my stock housing and put a HID reflector etc.. iit involves using an oven to open my existing headlight housing. The Retrofit Source has kits for this.
Has anyone on this site done this?
Is there a HID 2012 Mazda 3 headlight that did NOT utilize the steering column that i can use instead of taking apart my stock headlight?
Jordan 100
2012 Mazda 3 Sport
post #7 of 9 (permalink) Old 01-20-2016, 10:29 PM
I have done this conversion and I would say its safe and excellent result, but now I'm itching for LED...
hellfaller is offline
post #8 of 9 (permalink) Old 01-21-2016, 05:43 AM
Google this: morimoto HID recall
FusionS2007 is offline
post #9 of 9 (permalink) Old 02-07-2016, 01:17 PM
beavis87 is offline
LinkBack to this Thread: http://www.mazda3forums.com/673-2010-2013-exterior-lighting/696561-hid-conversion-should-i-do.html
2010-2013 Exterior Lighting [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 12-12-2015 07:22 PM
FMVPerformance.com Network: The sites for all your Ford Mazda and Volvo Needs This thread Refback 12-07-2015 08:13 AM
hid conversion rdk 2004-2009 Exterior Lighting 23 07-13-2009 08:00 AM
(noob) HID conversion kit spacer poblems, fog lights, and HID HI beams ducatidoc 2004-2009 Exterior Lighting 19 12-23-2007 05:26 AM
HID Conversion dovidio815 2004-2009 Exterior Lighting 10 05-13-2007 08:34 PM
Need help with HID conversion please!!! tlj 3 2004-2009 Exterior Lighting 5 10-11-2006 12:02 AM
HID Conversion: About How Much!? civicex2g 2004-2009 Exterior Lighting 1 06-04-2004 10:07 AM
