Which LED for headlights and fog lights 2012? - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 7 (permalink) Old 02-05-2015, 01:19 PM Thread Starter
Hi all;
Just trade my old 2004 3s HB for a 2012 3s HB and missing my HID headlights... so I'm planning to install LEDs for high/low/fog beans but there is a multitude of types and wattage and I'm lost needing some info.
Which ones are the brighter and whiter ones? Are they inside Mazda specs (current draw). Where to buy (Amazon, Ebay or other site)? Are they easy to replace or require a lot of disassembly?
Thank you for the help
Cheers
Speed
Second time marriage: the rompant victory of hope over reason....
speedmaster is offline
post #2 of 7 (permalink) Old 02-06-2015, 10:05 AM
spencer's Avatar
I wouldn't install LEDs. The optics of your headlight are designed specifically for a halogen bulb. An LED (or HID) bulb gives a different distribution of light than a halogen bulb. Using anything other than halogen bulbs in halogen headlights would make them illegal, unsafe, and less effective.
Edit: here is a thread where someone tested an LED replacement for a halogen bulb on what looks to be a newer Mazda 5. http://www.candlepowerforums.com/vb/...-LL-H11-100-H9
spencer is offline
post #3 of 7 (permalink) Old 02-06-2015, 02:08 PM Thread Starter
Thanks for the heads up. Any suggestions of a good, strong and white halogen lamp? The whiter the better....
Cheers
Speed
post #4 of 7 (permalink) Old 02-06-2015, 03:24 PM
spencer's Avatar
Cheers
Speed
I would get something from a reputable company like Philips, Osram, GE, etc. They all make bulbs that are brighter at the expense of lifespan. I've heard a lot of good things about Osram 65W bulbs but haven't used them myself. Sylvania Silverstars are one example of a whiter bulb, because they have a little bit of blue filter on the bulb surface. Unfortunately, this filter reduces the total amount of light that makes it to the road.
All of these bulbs would be a small upgrade over stock, but won't be near that of HID performance. If you want HIDs, the only legal solution is to get the OEM parts.
spencer is offline
post #5 of 7 (permalink) Old 02-06-2015, 06:35 PM Thread Starter
Yeah, I miss my 2004's hids... but won't go this way. Will try one of the Syvanias or Philips. Are the low and hi beam lamps the same part #?
Thanks for the reply. Cheers
post #6 of 7 (permalink) Old 02-06-2015, 07:28 PM
spencer's Avatar
Bulb information should be in your owner's manual or at this link: http://www.sylvania.com/en-us/applic...s/lrgmain.aspx
spencer is offline
post #7 of 7 (permalink) Old 02-13-2015, 05:07 PM Thread Starter
Anyone with carxenonhidkits installed?
If yes can you give me a review regarding the light, durability, ease of installation and any problems found during installation and after?
Cheers
Speed
LinkBack to this Thread: http://www.mazda3forums.com/673-2010-2013-exterior-lighting/663762-led-headlights-fog-lights-2012-a.html
Which LED for headlights and fog lights 2012? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 01-22-2018 12:23 PM
2010-2013 Exterior Lighting [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-19-2015 09:51 AM
fog lights without headlights badactor502 2004-2009 Exterior Lighting 2 06-08-2010 06:09 PM
HID Fog lights and Headlights allen624 2004-2009 Exterior Lighting 2 02-14-2010 02:47 PM
Turning fog lights on without headlights phantom3 2004-2009 Exterior Lighting 1 06-26-2007 03:02 AM
