adding oem fog lights and switch... - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 12 (permalink) Old 11-20-2014, 04:58 PM Thread Starter
Ive searched the forums and didn't see exactly what I'm looking for. I've got a 2011 mazda3 i sport sedan and I want to add the fog lights. I found this kit on eBay which includes a new light switch. http://m.ebay.com/itm/290739243749?nav=SEARCH
Is this a relatively easy install? From what I've read the wiring harness should be there and these lights will bolt on and plug in. Is this correct?
Ray D is offline
post #2 of 12 (permalink) Old 11-21-2014, 07:47 PM
Mazda3S08's Avatar
The wiring should be present in your car regardless of the model. It should be a plug and play application. However if the part is not genuine oem you may need to do some rigging of some sort to get the desired results.
Mazda3S08 is offline
post #3 of 12 (permalink) Old 11-28-2014, 11:31 AM Thread Starter
I ordered the oem parts off of eBay. I'm guessing there's no other way to install the fog lights than removing the front bumper or can you get them on from underneath?
Ray D is offline
post #4 of 12 (permalink) Old 11-28-2014, 07:31 PM
Mazda3S08's Avatar
To install them you will need to remove the bumper. They Screw on to certain holes that were predrilled at the factory.
post #5 of 12 (permalink) Old 11-29-2014, 10:47 AM
Send a message via AIM to biking4jesus
its best/easiest to take the bumper off. you could theoretically do it by removing the bottom splash shields and reaching in, but that would be pretty difficult.
The kit/part you ordered is the lights, housing, and wiring. you still need the switch (not included in what you ordered), unless you already have it.
the p/n for the switch is BBM3-66-122
its $45-65 - http://www.ebay.com/itm/NEW-OEM-FRON...-/360924243806
its pretty easy- plug and play into the steering column.
biking4jesus is offline
post #6 of 12 (permalink) Old 12-08-2014, 02:06 PM
Correct, please tell me you did not pay $312.00 for just the lights
http://www.tascaparts.com/oe-mazda/b...tr=BDL4-V7-220
http://www.tascaparts.com/oe-mazda/b...tr=BBM3-66-122
Chris
Chris
Employee pricing on all Mazda OEM parts and accessories!
TASCAPARTS is offline
post #7 of 12 (permalink) Old 12-11-2014, 04:22 PM Thread Starter
I got the light kit for $100 and the switch for $50
Ray D is offline
post #8 of 12 (permalink) Old 12-15-2014, 08:34 PM
icspots's Avatar
Assuming the 2nd gen is the same as the first gen there are a few ways to do aftermarket add on fogs. If you use the factory wiring then you could connect the new fogs to the existing wiring in the bumper. You'd probably need to cut the connectors as I doubt the aftermarket housings would mate with the OEM plugs. Then you'd need to install the OEM turn signal stalk with the included fog light switch. That's it.
If you're installing an aftermarket switch then likely the kit will want you to independently wire the fog lights for power. Not really a big deal as you'd just need to tap power (battery), a signal wire, a ground, and the switch. I'm imagining this is one of those rectangular switches which goes next to the steering wheel in the blanks on the dash?
icspots is offline
post #9 of 12 (permalink) Old 12-28-2014, 06:54 PM Thread Starter
How do i get access to the steering column to remove the old one and install the new one? I saw two screws on the bottom and I removed those which loosened it up a little, but not much. What else needs to be done to get it off without breaking it?
Ray D is offline
post #10 of 12 (permalink) Old 12-30-2014, 09:47 PM
icspots's Avatar
Remove those two screws you found. Extend and lower the wheel as much as you can. Grab the rubber cover on the top and work your way around it popping it loose from the top plastic part. That part should come off then.
There are a few screws holding the stalk into the column (I think, it's been a while). Unplug the harness from the base of the stalk, then pull the bottom section down just far enough to slide the base of the stalk out of the column.
Reinstall in reverse.
icspots is offline
LinkBack to this Thread: http://www.mazda3forums.com/673-2010-2013-exterior-lighting/654154-adding-oem-fog-lights-switch.html
2010-2013 Exterior Lighting [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-30-2015 01:54 PM
Adding Fog Lights mazda3_05 2004-2009 Exterior Lighting 10 02-17-2010 02:52 PM
Question about adding Fog lights Drewsiph87 2004-2009 Exterior Lighting 1 09-16-2009 10:54 AM
WTB: OEM Headlight/Turn Signal switch with fog switch - need ASAP daustin For Sale | M3F 2 07-31-2009 06:41 PM
Adding Fog Lights to an '06 GS - Info & Experiment Artemis * Canada 15 10-10-2006 12:06 PM
