trouble adjusting height of headlight beam - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 14 (permalink) Old 05-31-2014, 10:26 AM Thread Starter
Exclamation trouble adjusting height of headlight beam
My driver side headlight had trouble adjusting, turning the switch or whatever you want to call it.. (it would turn but there would be no difference in height)
the passenger side had no issues..
curious to know if there is an easy fix for that? I need my beams to be lower, HIDs seem to be doing no help because of how high they are...
thaaaanks (:
Maxusiaa
maxusiaa is offline
post #2 of 14 (permalink) Old 05-31-2014, 11:16 AM
philrab's Avatar
Factory auto leveling HID, or stock halogens you converted to HID?
philrab is offline
post #3 of 14 (permalink) Old 05-31-2014, 12:35 PM Thread Starter
stock halogens, just put an HID kit in but that shouldn't have anything to do with it.
I figured out how to adjust them, its just that the drivers side seems to be broken i guess
I'm guessing the previous owner messed around with it or something.
The little screw or nob you twist, does rotate, but it doesnt change the height at all of the beam
idkk does that make sense
Maxusiaa
maxusiaa is offline
post #4 of 14 (permalink) Old 05-31-2014, 01:15 PM
There are two screws; one does height, one does rotate.
That said, if you only just swapped in HID bulbs and have to adjust, then the problem is the bulbs, not the aim of the headlight.
The only time you need to adjust the aim is when you take it apart; but even the gen2s don't have that problem, they got smart with the headlights.
If your beam pattern is off, your bulbs are either A cheap junk that should be replaced with quality bulbs, B not the right bulb.
post #5 of 14 (permalink) Old 06-01-2014, 12:42 AM Thread Starter
But if the right side is the same exact bulb and it adjusts then the drivers side should as we..
Maxusiaa
maxusiaa is offline
post #6 of 14 (permalink) Old 06-01-2014, 07:29 AM
Both of them can adjust, like I said there are two adjustable screws that if you open the hood and look down on the backside of them you will see them (gen1s had a little white cap on them you had to remove, I think gen2s got rid of it because it made no difference.. I think, I could be wrong.)
What I'm getting at though is you shouldn't have to adjust your headlights after doing HIDs, unless something is wrong.
post #7 of 14 (permalink) Old 06-02-2014, 01:11 PM Thread Starter
no they are pretty cheap HIDS, they do the job but if i adjust them both a little lower they'll be more brighter,
I know the screws adjust them, I have already done it, like I said, the right side does work, the drivers side screw twists but doesn't adjust the headlight meaning its broken, I was just wondering if there's an easy fix for that screw..?
Maxusiaa
maxusiaa is offline
post #8 of 14 (permalink) Old 06-02-2014, 02:33 PM
Is it broken broken or is it the tool you're using?
The first time I adjusted my headlights the screwdriver I was using wasn't large enough and it wasn't grabbing the teeth.
Then I realized they were actual bolts, so I just took a ratcheting wrench and went at them; 9mm maybe
post #9 of 14 (permalink) Old 06-03-2014, 12:24 AM Thread Starter
They were able to be turned by hand,
I know something is wrong with the screw, because the passenger side adjusted with no issues.
Maxusiaa
maxusiaa is offline
post #10 of 14 (permalink) Old 06-03-2014, 06:51 AM
unless it was adjusted too far to where it fell off the screw... but that shouldn't be allowed to happen, unless it went so far that it got stripped?
It may require taking the headlight out and apart to see what's going on.
At least off the car, which isn't too hard, hopefully not apart but definitely sounds like something is not.. right.
LinkBack to this Thread: http://www.mazda3forums.com/673-2010-2013-exterior-lighting/628122-trouble-adjusting-height-headlight-beam.html
2010-2013 Exterior Lighting [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-20-2015 11:28 AM
headlight adjusting black07spd 2004-2009 Exterior Lighting 2 12-05-2010 09:12 PM
Headlight level manual adjusting OkiE3 2004-2009 Exterior Lighting 0 08-14-2009 05:50 PM
Did you adjust beam height after? ikon Exterior Lighting Technical Information, FAQ's, How-To's 1 07-04-2007 01:07 PM
Need Help Adjusting my Low beam drdellorama Southwest 1 06-05-2007 03:30 AM
low beam headlight 5eif 2004-2009 Exterior Lighting 2 04-30-2007 10:31 AM
