morimoto hid kit - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 22 (permalink) Old 05-20-2014, 09:29 PM Thread Starter
morimoto hid kit
want to get a 35 watt kit for my 2013 mazda 3 isport. Can someone tell me which kit i need? I have the h11 kit in the cart. but i read somewhere someone had to buy a different bulb. just want to make sure i get right part.
$treetwise is offline
post #2 of 22 (permalink) Old 05-21-2014, 08:47 AM
philrab's Avatar
You need whichever kit is appropriate for your low beam bulb. Sylvania has a nice bulb chart/lookup feature on their website.
philrab is offline
post #3 of 22 (permalink) Old 05-21-2014, 09:17 AM Thread Starter
They only have fog lights listed for my car no headlights
post #4 of 22 (permalink) Old 05-21-2014, 09:57 AM
philrab's Avatar
H11 bulb is what's listed in Sylvania's bulb guide for your model year with halogen high and low beams.
philrab is offline
post #5 of 22 (permalink) Old 05-22-2014, 07:57 AM Thread Starter
thank you. Ordered a set yesterday and will be here and installed tomorrow.
post #6 of 22 (permalink) Old 05-23-2014, 01:36 PM Thread Starter
Question...I just got my kit and im going to hook up tonight. On each bulb there is wires connect with plugs that go into the two wires coming from ballast. However next two It is two wires with pins and opposite end has a plug. Do I need this.? also does the wire harness get hooked directly into the +/- on battery? im use to cheap ebay ones. I want to make sure I hook up right.
post #7 of 22 (permalink) Old 05-23-2014, 02:08 PM
brandini's Avatar
Read the instructions.
It should be battery-fuse-relay-ballasts-headlights and another loop from stock headlight wires-relay to trigger the relay.
brandini is offline
post #8 of 22 (permalink) Old 05-23-2014, 02:11 PM Thread Starter
I read there crappy instructions. It doesn't show on there.
post #9 of 22 (permalink) Old 05-23-2014, 02:28 PM
philrab's Avatar
A. There are separate instructions for the relay harness that plainly answer your question. They're available on TRS' website.
B. The plug you mention is on the driver side of the relay harness, and plugs into the stock headlight plug. That gives your relays signal to energize.
C. The positive lead of the relay harness(fused end) connects to the positive post on your battery. Each end of the relay harness near the ballast has a ground wire, and these ground directly to chassis.
philrab is offline
post #10 of 22 (permalink) Old 05-23-2014, 02:47 PM Thread Starter
the wires I am talking about are through the rubber piece of light bulb. there is the two plugs that go to ballast. THen there is two pin wires that run to a plug. I do not see them on a diagram.
LinkBack to this Thread: http://www.mazda3forums.com/673-2010-2013-exterior-lighting/626177-morimoto-hid-kit.html
morimoto hid kit - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 01-22-2018 11:32 AM
2010-2013 Exterior Lighting [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-29-2015 09:17 PM
Morimoto D2S HID Bulbs 35W for sale! eliwwjd777 For Sale | M3F 1 03-21-2014 01:21 PM
GB: TRS MORIMOTO ELITE HID SYSTEM! chubbs M3F Group Buys (Completed) 26 06-22-2013 06:56 PM
Morimoto Elite HID System led00d 2010-2013 Exterior Lighting 1 01-21-2013 09:07 AM
Morimoto HID Bulbs wildfrisco 2004-2009 Exterior Lighting 0 06-01-2011 09:49 PM
