morimoto hid kit - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum
post #11 of 22 (permalink) Old 05-23-2014, 04:38 PM
philrab's Avatar
Oh, I see now.
http://www.theretrofitsource.com/diy...ulb-guide.html
That's the explanation for the extra wires. I don't believe they are required for your install. I know they aren't in the first gens.
philrab is offline
post #12 of 22 (permalink) Old 05-23-2014, 04:54 PM Thread Starter
thanks. Im about to send this back. There is not good enough instructions to install this or I don't understand it. There is not a plug left for one of my factory wires to plug into. Plus when I pulled this harness out there is a double sided plug plugged into the relay that's not shown in the picture either.
$treetwise is offline
post #13 of 22 (permalink) Old 05-23-2014, 05:21 PM
philrab's Avatar
I ordered the same kit, and had no such issues.
philrab is offline
post #14 of 22 (permalink) Old 05-23-2014, 05:36 PM Thread Starter
did you have one factory plug (plug that went into your original headlight) not hooked into anything? when using a relay?
post #15 of 22 (permalink) Old 05-23-2014, 08:05 PM
philrab's Avatar
That's correct. Passenger side factory plug will not connect to anything. I just capped it off with silicone to keep corrosion out, and zip tied it out of the way.
Relay harness only needs one turn on signal, hence only one spot to plug the original headlight wiring into the harness.
philrab is offline
post #16 of 22 (permalink) Old 05-23-2014, 08:12 PM Thread Starter
cool thanks. I just finished hooking up. Last question. My drivers side when i turn it on flickers once when they come on and then its consistent. Does this sound ok. Other than that they are staying on.
i have two grounds to fender. one to the battery then all connections other than passenger
post #17 of 22 (permalink) Old 05-23-2014, 11:25 PM
philrab's Avatar
Give the bulbs a few hours of run time to break in. If the flicker continues, I'd contact TRS tech support by email of phone and they will happily help you figure it out.
Where your ballasts are grounded, did you sand the paint out from under the connections for the best possible ground? That can cause this issue.
philrab is offline
post #18 of 22 (permalink) Old 05-23-2014, 11:56 PM Thread Starter
ballast are bolted near strut bolts. no i didn't sand that area. i will try that. It flickers when the ballast ignites and is good after that.
post #19 of 22 (permalink) Old 05-24-2014, 12:24 AM
philrab's Avatar
Mine did the same, it lasted a couple of hours of run time. Just wanted to rec you sand down the ground spots to prevent a possible issue down the road.
philrab is offline
post #20 of 22 (permalink) Old 05-28-2014, 02:06 PM Thread Starter
thanks. That's what TRS said too.
LinkBack to this Thread: http://www.mazda3forums.com/673-2010-2013-exterior-lighting/626177-morimoto-hid-kit.html
morimoto hid kit - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 01-22-2018 12:32 PM
2010-2013 Exterior Lighting [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-29-2015 10:17 PM
Morimoto D2S HID Bulbs 35W for sale! eliwwjd777 For Sale | M3F 1 03-21-2014 02:21 PM
GB: TRS MORIMOTO ELITE HID SYSTEM! chubbs M3F Group Buys (Completed) 26 06-22-2013 07:56 PM
Morimoto Elite HID System led00d 2010-2013 Exterior Lighting 1 01-21-2013 10:07 AM
Morimoto HID Bulbs wildfrisco 2004-2009 Exterior Lighting 0 06-01-2011 10:49 PM
