Fog lights - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 13 (permalink) Old 10-21-2013, 01:24 PM Thread Starter
NotoriousMazda's Avatar
Fog lights
Just bought the 2010 mazda 3 I sport. It has fog lights but no bulbs in them. I was wondering if I could buy and put in hid light bulbs in this fog light assembly
Sent from AutoGuide.com App
NotoriousMazda is offline
post #2 of 13 (permalink) Old 10-21-2013, 01:49 PM
philrab's Avatar
Attachment 68594
As long as the housings are slotted on the back side for a bulb, and you know what type of bulb you need, I don't see why not.
Personally, I'm spending my money to stick 5000K HID's in the low beams, and use halogens with Lamin-X yellow overlays on the fog lights. I don't see the fog lights adding a lot of visibility out the front of the car compared to a good HID kit in the low beams.
philrab is offline
post #3 of 13 (permalink) Old 10-21-2013, 02:03 PM Thread Starter
I'm really new to all this and I don't mean to ask so many questions but I don't know what you mean by slotted housing. Here's a picture of inside the fog light. Can you tell if it will work from this picture
post #4 of 13 (permalink) Old 10-21-2013, 02:14 PM
philrab's Avatar
Attachment 68602
What I mean is, as long as the back of the housing actually has a spot for a bulb, then you just need a bulb (HID retrofit or halogen) designed to fit that housing. I believe your fog lights take an H11 bulb.
Oddly enough, from the pic, it looks like you already have bulbs installed. Are your fog lights currently working, and you're just asking if you can retrofit HID's into them?
philrab is offline
post #5 of 13 (permalink) Old 10-21-2013, 02:25 PM Thread Starter
I'm such an idiot hahaha yeah I turned them on and they work. But I do want to put hids in place of them. So retrofit hids in them I guess that's what I was asking
post #6 of 13 (permalink) Old 10-21-2013, 02:33 PM
philrab's Avatar
Yes. Make doubly sure of the bulb type you need (I'm pretty sure it's H11, but pull one out and check the number on it just to be safe). I'm getting TRS/The Retrofit Source for my low beams, but they are pricey at $150. For fog lights, since they're not your primary source of illumination when driving, I'd look at DDM or a cheaper kit to save the cash. Your call, there are plenty of opinions out there.
You may want to rename this thread using the edit function (or, as a moderator, I can for you) to ask for HID recommendations for the fog lights, just so that people know what it is you're looking for. If you like the yellow fog look (like I do) look for a kit with 3000K bulbs, otherwise get whatever color you like the look of.
philrab is offline
post #7 of 13 (permalink) Old 10-21-2013, 02:36 PM Thread Starter
Thanks so much! I'm excited to start modding the car! Now I just have to find the thread on how to replace fog light bulbs lol
post #8 of 13 (permalink) Old 10-21-2013, 02:46 PM
philrab's Avatar
If you had an 04-09, I'd know. I can't imagine it's very difficult though. Just take apart whatever you have to access the backs of the fog housing, detach the wiring plug from the bulb, and the bulb should twist counterclockwise or clockwise about 1/4 turn and pop straight out. Installing the HID retro bulb will be the same. Wiring is dependant upon the kit (whether or not it uses a relay harness like the nicer kits do, or uses the stock wiring harness to provide all the voltage.)
philrab is offline
post #9 of 13 (permalink) Old 10-22-2013, 10:24 AM Thread Starter
What's your opinion on installing halos in the head light unit or buying the whole head light unit with halos in it? Do you know of a reputable place to buy these u it's from? Just bought hid fog lights very excited to install them!
post #10 of 13 (permalink) Old 10-22-2013, 10:30 AM
philrab's Avatar
There are others here more knowledgeable about installing halos. I've heard pretty mixed reviews of the quality of the projectors in aftermarket units, but someone may have direct experience with a set that works well.
The catch 22 is an aftermarket unit comes preassembled, installing halos in your existing units requires baking the headlights open. Baking open headlights isn't without some risk of screwing things up, but buying aftermarket you pay more and risk getting poor quality lighting in the end.
philrab is offline
LinkBack to this Thread: http://www.mazda3forums.com/673-2010-2013-exterior-lighting/560930-fog-lights.html
2010-2013 Exterior Lighting [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-06-2015 04:46 AM
wiring hid fog lights with aftermarket spyder fog houses kglazer 2004-2009 Exterior Lighting 1 08-19-2012 08:01 PM
Turn on fog lights without turning on main lights? Liustyle 2004-2009 Exterior Lighting 7 10-19-2009 05:22 PM
Halo lights and fog lights hamholla 2004-2009 Exterior Lighting 3 09-23-2009 09:12 PM
LF: GT bumper (fog lights and grille) or gt fog lights SANDMICA3 For Sale | M3F 7 02-28-2009 05:56 AM
WTB: OEM 3i fog lights and S Sedan Tail Lights pipejaimes For Sale | M3F 3 10-10-2006 08:52 PM
