Fog lamp replacement on 2013 M3 SkyActiv HB - easiest way to change? - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 3 (permalink) Old 07-29-2013, 05:01 PM Thread Starter
tremoloman's Avatar
Hello everyone,
I bought a pair of LED fog lamps from Corksport and would like to know:
What is the easiest way to install them?
I see some people mention taking off the bumper, others say back the car up and take off splash guards. I'm just looking for the simplest way to change them with the least amount of effort since taking apart a brand new makes me cringe.
Best regards,
Trem
tremoloman is offline
post #2 of 3 (permalink) Old 07-29-2013, 09:21 PM
Are you installing the whole assembly yourself or just replacing the bulbs? On the 2013's there are plastic plates below the bumper on each side that are held in by 3 screws. Removing these should give you access to replace the bulbs. Look on page 8-48 of the owner's manual for more details. If you are installing the whole assembly, I would guess that you have to remove the bumper, but I'm not totally sure.
Juggernaut is offline
post #3 of 3 (permalink) Old 07-30-2013, 08:52 AM Thread Starter
tremoloman's Avatar
I am just looking to change the bulbs. I will look at the manual and give this a shot.
Thank you for the reply and I'll post my results shortly.
Best regards,
Scott
LinkBack to this Thread: http://www.mazda3forums.com/673-2010-2013-exterior-lighting/501266-fog-lamp-replacement-2013-m3-skyactiv-hb-easiest-way-change.html
2010-2013 Exterior Lighting [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 02-15-2016 12:41 AM
Fog Lamp Bulb LED Replacement leeharvey418 2004-2009 Exterior Lighting 8 08-18-2011 05:02 PM
2008 Mazda 3S 5dr factory rt. fog lamp needs replacement- need instructions chaseme5 2004-2009 Exterior Lighting 3 03-26-2010 02:26 PM
Replacement oem fog lamp glass for an 07 GT? Ronsa 2004-2009 Exterior Lighting 1 09-19-2008 10:08 AM
Source for replacement factory fog lamp? eury 2004-2009 Exterior Lighting 8 09-20-2007 10:28 PM
