Help removing brake light bulb in 2012 GT - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 5 (permalink) Old 05-12-2013, 10:02 PM Thread Starter
Lumber-jack's Avatar
I can get the turn signal bulb out no problem by twisting counter clockwise however the brake light bulb doesn't appear to be the same. If I twist any harder I think I am gonna break it. I have looked in the OEM service manual and it appears that there is two different types of connections. The other type being you have to take the nuts off from inside and remove the entire assembly. How do I confirm which type I have without taking the assembly apart? Would this be an LED type bulb then in the brake light and a halogen in the turn signal?
If you want to feel smart - get stupid freinds...
Lumber-jack is offline
post #2 of 5 (permalink) Old 05-13-2013, 08:43 PM
Do you have the tech package with LED tail lights? If so then you cannot remove the LED assembly like the turn signal bulb. If it is not the LED lights then it will turn and pull just like the turn signal bulb.
2011 Mazda 2 Sport - 5-speed manual - First retrofitted Mazda 2 in North America - TOTALED
2012 Mazda 3i Touring Skyactiv - 6-speed manual - Corksport CBE w/RP, TRS Black Series clear lenses with DDM 4500K low beams-9011 HIR1 high beams-Full LED conversion in progress
1stGenRX7Addict is offline
post #3 of 5 (permalink) Old 05-14-2013, 10:11 PM Thread Starter
Someone in another forum said the GT comes with LED brake lights. Now why would they have halogen turn signals but make the brake lights LED?
post #4 of 5 (permalink) Old 05-15-2013, 12:51 AM
Send a message via AIM to cclngthr Send a message via MSN to cclngthr
Easier to keep the resistance in the circuit for the turn relay.
cclngthr is offline
post #5 of 5 (permalink) Old 05-16-2013, 09:29 PM
Cost and design limitations. LED signals aren't common on lower prices vehicles but will be in due time.
LinkBack to this Thread: http://www.mazda3forums.com/673-2010-2013-exterior-lighting/461377-help-removing-brake-light-bulb-2012-gt.html
2010-2013 Exterior Lighting [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-17-2015 02:17 PM
2012 Mz3 Fog light bulb? aitch 2010-2013 Exterior Lighting 1 11-24-2011 01:56 PM
Removing map light bulb m14andre Mazda3 (Axela) 2 03-14-2009 07:55 PM
brake light bulb replacement cruelworld 2004-2009 Exterior Lighting 3 02-14-2009 10:52 AM
Brake Light Bulb Number? JustinsMazda3 2004-2009 Exterior Lighting 4 08-11-2005 06:39 PM
