My DRL mod with pics - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 6 (permalink) Old 03-18-2013, 11:26 PM Thread Starter
Greetings all! Just purchased a new 2012 Mazda 3 i Touring, and I'm shipping it to England (Air Force). Unfortunately for me, I found out AFTER I purchased the car that they are requiring daytime running lights. I really like the look of the little ones that fit in the upper corner of the "smile" but I don't have that kind of money right now with everything we're saving up for. So, I found a nice alternative at the local PepBoys and thought I would give it a try.
[/IMG]
The kit came with two 4-LED lights, 2 mounting brackets, 1 control module, 4 screws, some zip-ties, and a splice.
[/IMG]
Here are some pics I took while doing the mod because I know everyone would want them! Here are the steps I took also.
First, I removed the front bumper, which was not too bad.
Next, I had to figure out where I was going to mount the lights. I finally decided on the mid part of the grill where there are plastic fairings behind the grill.
[/IMG]
I made a template out of cardboard so I would drill the holes out correctly, then I proceeded to cut the plastic grill section that the lights would fit through.
[/IMG]
Pics with the grill cut out and holes for the bolts.
[/IMG]
I had to get 4 M5 bolts as the kit didn't come with them. You are able to mount the lights without the brackets if you mount them from the back side. Here is a pic of the light mounted in the grill.
Here is a pic of the screws from behind the grill
I routed the wires behind the bumper and through the hole at the top on the drivers side where the wires for the fan go through.
I installed the control module on the small relay cover directly in front of the main fuse box. Since there was only one relay in there, I mounted it with the screws on the side that was empty.
I routed the wires that connect to the battery through the hole on the bottom of the battery tray, secured them and connected them to the + and - terminals.
There is an orange wire from the control module that you splice in to the marker light wire. On the drivers side, I found the plug leading to the lights, and pulled it apart. The wire color was actually the orange wire, so I spliced behind the plug (NOT on the harness connected to the light assembly).
I connected the lights to the control unit, checked them, and they worked great! Just secured all the extra wire, bolted the bumper back on, and now I have DRL's on the Mazda!
If you have any questions about my install, let me know.
Penshockeyfan is offline
post #2 of 6 (permalink) Old 03-19-2013, 12:31 AM
ultimica06's Avatar
I got the same Phillips DRL's..
I unhooked the Orange wire so they work w/ the headlights on also!
ultimica06 is offline
post #3 of 6 (permalink) Old 03-19-2013, 04:49 AM
222speed3's Avatar
Looking good man
Clean job and nice write up
Like the location of the lights as well
222speed3 is offline
post #4 of 6 (permalink) Old 03-19-2013, 11:20 AM Thread Starter
ultimica06 - I had to hook up the orange wire because the requirements in the UK are that the DRL's must go out when the headlights come on. I would check your state regs for that also, depending on if you have an inspection in your state or not.
Thank you 222speed3! They mounted very nicely to that fairing behind the grill.
post #5 of 6 (permalink) Old 07-12-2015, 04:16 PM
I think your DRLs look very good! Which are those little ones you are talking about?
patoestavillo is offline
post #6 of 6 (permalink) Old 07-12-2015, 05:43 PM
Mazda3S08's Avatar
wow! great write up man. everything came out mint.
Mazda3S08 is offline
LinkBack to this Thread: http://www.mazda3forums.com/673-2010-2013-exterior-lighting/418945-my-drl-mod-pics.html
Automatyczne ?wiat?a, fabryczne dzienne, monta? DRL (10/13) This thread Refback 11-02-2015 09:34 AM
2010-2013 Exterior Lighting [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-11-2015 01:14 AM
Installed: Eurolite Yellow Highbeams DRL's *PICS* ladiesman217 2004-2009 Exterior Lighting 15 01-09-2009 02:41 PM
how to wire angel eyes to make DRL? EDIT: Sorry meant to put DRL! ttruong25 2004-2009 Exterior Lighting 18 09-12-2007 08:48 PM
Handbrake DRL disabling and foglight as DRL mbanx9999 2004-2009 Exterior Lighting 0 08-23-2005 04:37 AM
