2010 Mazda3 s Sport Fog Light Replacement - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 4 (permalink) Old 10-31-2012, 07:02 PM Thread Starter
Send a message via Skype™ to raceking92
I just bought a 2010 Mazda3 s Sport (10/25/12). Today I walked to my car and looked at my fog lights only to see my driver side fog lens cracked pretty badly.
It must have happened within the last two days and I know I didn't hit anything because there is no surrounding damage. So my question was how expensive are the Fog Light assemblies how difficult are they to replace??
Thanks for the time!!
A.S.K.
raceking92 is offline
post #2 of 4 (permalink) Old 12-07-2012, 02:05 PM
Currently have the same issue. Check out Amazon. I found replacements for around $70 which is much better than the cost of OEM. Probably going to use lamin-x on boths side when i finally get to it. The install doesn't seem too bad. I've read instructions suggesting you need to remove the bumber, other without. But it's only about 3 bolts that hold the thing in there so it shouldn't be too bad a change.
DoctorZ87 is offline
post #3 of 4 (permalink) Old 12-08-2012, 10:39 AM
kirktcashalini's Avatar
I've had mine out a few times, to vinyl them as well... If you can take the bumper off (easy) you can swap the fog light in about 3 mins after that...
kirktcashalini is offline
post #4 of 4 (permalink) Old 12-17-2012, 06:52 PM Thread Starter
Yeah I just got quoted for $250!!
The actual fog light assembly is around $160. So I'm def. gonna check out Amazon to do it myself.
My lamin-x is on the way!
Thanks!
A.S.K.
LinkBack to this Thread: http://www.mazda3forums.com/673-2010-2013-exterior-lighting/401836-2010-mazda3-s-sport-fog-light-replacement.html
2010-2013 Exterior Lighting [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-20-2015 05:02 PM
mazda3 sport 2010 HID KIT ?? andypr_2010 Mazda3 (Axela) 5 09-12-2010 03:01 AM
Clutch replacement on a 2004 Mazda3 Sport 2.3 Big Dee Powertrain 2004-2009 Mazda3 0 10-09-2009 09:41 AM
