Halogen Tails to LED tails swap - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 12 (permalink) Old 09-14-2012, 12:39 AM Thread Starter
I've seen on the 2.5 iTouring models it has an LED brake lamp assembly (on the 5-door hatches).
Is it essentially plug-and-play if I were to swap out the halogen brake lamp assembly to the LED's? I've looked page-for-page in the exterior lighting and couldn't find anything directly related to it.
k.trazy is offline
post #2 of 12 (permalink) Old 09-14-2012, 01:40 AM
It is a direct replacement. The brake lights are LED but the turn signals are still halogen, you can get LED bulbs to go in them. CorkSport sells the LED tail lights for the hatchback. You can also just put in LED brake light bulbs in the existing housings if you want to go with that look.
-Shaun
phoenixosu is offline
post #3 of 12 (permalink) Old 09-14-2012, 02:00 AM Thread Starter
I quite like the look of the OEM LED tail lamp assemblies. Essentially just wanted to know wether or not if I needed anything additional for the OEM LED's. Thinking of swapping out assemblies, and like you suggested, switch out the halogen turn signal bulbs for LED's for both front and back for a constant effect.
Thanks for the reply!
k.trazy is offline
post #4 of 12 (permalink) Old 09-14-2012, 10:07 AM
parabolous's Avatar
Well if you change the turn signals to LED's you might experience hyper flashing. In which case you will need to get some load resistors.
parabolous is offline
post #5 of 12 (permalink) Old 09-14-2012, 10:56 PM Thread Starter
Good point. Still would look brilliant. I'd dig it!
k.trazy is offline
post #6 of 12 (permalink) Old 09-19-2012, 10:04 PM
I've noticed that the LED turn signal bulbs I've used in front (switchbacks) and rear (7W yellow LEDs) are just not that visible during daylight. At night they look great but I can see it being tough to see them during the day. It's odd how they seem brighter than halogen at night but dimmer in daylight, I think it has to do with the spectrum of light. You will want to use some high power LEDs if possible. The front spot does accommodate switchbacks from v-leds but those are about as big as I can fit in there as they just about touch the sidewall of the reflector they sit in, the back ones have lots of room for whatever you want.
-Shaun
post #7 of 12 (permalink) Old 09-20-2012, 12:10 AM
parabolous's Avatar
It's pretty much impossible to get visible, bright LED's for turn signals. Especially the rear because if you're driving away from the sun the people behind you will just not see it as well. Now if you spend $70+ on Putco LED's it would be a little more visible.
Like Phoenix said, they seem a lot brighter at night. Which is true for the turn signals. LED's are amazing for the most part, but sometimes they can be a damn hassle.
post #8 of 12 (permalink) Old 09-20-2012, 11:10 AM
Yeah I have LED turn signals in mine, and I always wonder if people behind me could even see it when the suns beaming behind me. It's funny I just saw this thread because I was just thinking the opposite, would halogen tails swap with LEDs? Would it have socket for my brake light?
.: Nothing Is Impossible :.
^^click it^^
m3_love is offline
post #9 of 12 (permalink) Old 09-20-2012, 11:25 AM
parabolous's Avatar
Do you mean if you had LED tails stock and switched to halogen would it work?
I believe the socket would work, though I never thought of that.
post #10 of 12 (permalink) Old 09-20-2012, 05:01 PM
Yeppers. lol I had a old pair laying around from my previous 04 mz3.
I guess, I'll let you guys know soon enough aha. Tomorrow?
^^click it^^
m3_love is offline
LinkBack to this Thread: http://www.mazda3forums.com/673-2010-2013-exterior-lighting/397868-halogen-tails-led-tails-swap.html
2010-2013 Exterior Lighting [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-24-2015 10:58 PM
Tail light poll: OEM LED tails of ebay LED tails? channelv Exterior Modifications 32 01-04-2011 08:14 PM
Hatch LED tails NIB $75 Stock Tails $100 Rear Aero flares $75 Ipod shuf. $25 w/p alpinemz3 For Sale | M3F 30 06-06-2008 07:13 PM
MOVED: Set of stock HB tails and aftermarket LED tails cheap $150 / $75 FemGearHead For Sale | M3F 0 05-22-2008 12:45 AM
MOVED: Trade Red Tails for S Tails Black/Clear Atlanta mz3szoomzoom For Sale | M3F 0 04-07-2007 10:58 PM
