seal on morimoto retro-quik system from TRS - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 4 (permalink) Old 06-30-2012, 06:58 PM Thread Starter
I'm installing the bi-xenon projectors from the retro-quik kit from TRS and I can't figure out how to seal the back of the headlights with the bulb, the new projects is so in-set from where the halogen was from the back that the old grommet won't make a seal to prevent water from getting in. any ideas?
-Shaun
phoenixosu is offline
post #2 of 4 (permalink) Old 06-30-2012, 08:51 PM
Re: seal on morimoto retro-quik system from TRS
Picture will help understanding your issue.
Which projector did you get? mini D2S or H1 or some OEM Bi-Xenon projector?
I don't have 2010+ housing spec detail with me but do you think one of rubber housing cap(what TRS sells) can fit?
upashi is offline
post #3 of 4 (permalink) Old 07-01-2012, 02:18 AM Thread Starter
Yea, the rubber ones from TRS will fit. The issue is the OEM grommet doesn't make contact with the D2S bulb I have, so the small gap could let water/dust in.
It's summer now so I'll chance it until some grommets arrive from TRS. I might make some kind of "temporary gromet" out of electrical tape to cover the area.
I did realize as I was putting the bumper back on that completely removing the bumper is not necessary to remove the headlights, wish I had known that when I started, but I did need to remove the bumper to put in the vented foglight trim and remove the silver fog light trim pieces for painting.
-Shaun
post #4 of 4 (permalink) Old 07-08-2012, 01:01 AM Thread Starter
I put the seal on, and then discovered that my seal job (overall) was not so good, after going thru a car-wash (my version of worst case scenario) and found a cloud of moisture near the turn signal on the drivers side. It also looked like some had gotten in the passenger side as well. I doubt I'll see much penetration in normal conditions tho since the car wash is a fairly intense water environment and not much got in. I will have to have these professionally sealed someday but being in Boise Idaho, I'm not going to fret about it.
-Shaun
LinkBack to this Thread: http://www.mazda3forums.com/673-2010-2013-exterior-lighting/395958-seal-morimoto-retro-quik-system-trs.html
2010-2013 Exterior Lighting [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-29-2015 09:25 PM
