lighting control questions - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 4 (permalink) Old 06-29-2012, 11:00 PM Thread Starter
I've done some experiments with removing headlights bulbs and so far no dash lights or warrnings or odd behavior, however, I don't have an obdii reader to be sure there are no trouble codes. If there is no load on the lighting lines for the stock halogen high beams and low beams as in when a demon retrofit is done with a harness, will any trouble codes pop up?
-Shaun
phoenixosu is offline
post #2 of 4 (permalink) Old 07-11-2012, 02:57 PM
Re: lighting control questions
not to my knowledge. The mazdas aren't the type of car to tell you your light is burned out. Which is a good thing because that makes it easier to mod the lighting system.
2012 Mazdaspeed3 in Black Mica
DuoofDeath1 is offline
post #3 of 4 (permalink) Old 07-18-2012, 10:45 PM Thread Starter
Found out that contrary to the information on some forums, the car will hyper blink if you have LEDs in front and back and only have ballast resistors in the front.
Also, amber LEDs inside the red brake light housing is unique, and not good looking to me, time to order the clear housings.
-Shaun
post #4 of 4 (permalink) Old 07-18-2012, 11:19 PM
yeah you'll have hyper blink if you have LED's...I mean its not bad, I kept mine lol people for sure know I'm turning.
.: Nothing Is Impossible :.
^^click it^^
m3_love is offline
LinkBack to this Thread: http://www.mazda3forums.com/673-2010-2013-exterior-lighting/395949-lighting-control-questions.html
2010-2013 Exterior Lighting [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 11-07-2017 10:28 AM
