Toggle Switches for Mazda 3 2011 Dash? - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 11 (permalink) Old 06-04-2012, 11:23 AM Thread Starter
Does anyone know where I could find some toggle switches that would fit the blanks to the left of my steering wheel in my Mazda 3 2011? I want to wire some exterior lights to a switch and I would like to use a standard looking location. Next to my traction control button would be great. I can't find the little half inch rectangle switch/button to fit there.
Stuart is offline
post #2 of 11 (permalink) Old 06-04-2012, 08:35 PM
john_in_the_lbc's Avatar
Re: Toggle Switches for Mazda 3 2011 Dash?
this might be more than you're looking for but Upashi has used the OEM switches for other stuff.
http://www.mazda3forums.com/index.ph...273#msg2987273
My car thread
john_in_the_lbc is offline
post #3 of 11 (permalink) Old 07-16-2012, 12:28 PM
It looks like Upashi paid $50 from mazda for the OEM switches; that's a bit more than i'm looking to spend for the 2 I'm trying to add. I mean the 2 switches will cost as much as on of the units i'm installing. Has anyone found anything close to OEM or at least anything that fits and doesnt look too crazy?
sotrbox is offline
post #4 of 11 (permalink) Old 07-17-2012, 10:16 AM
I'd be interested in this as well. Also, what's the best way to get to those switches for wiring and such? Can you just remove the trim panel around it or something? I would like to wire a switch for my footwell lights over there. Currently I have a switch wired in my center console.
becandl is offline
post #5 of 11 (permalink) Old 07-17-2012, 12:27 PM
Alternatively, you could just find a standard push button switch, take the blank switch panels, glue it to the the front of the switch, and voila, you now have a factory switch for much cheaper. Of course you still have to label it, but whatever, that's on you.
A revolution gets its name by always coming back around in your face.
smokinAMD is offline
post #6 of 11 (permalink) Old 09-07-2012, 10:23 AM
try McMaster-Carr. They've got every kind of switch imaginable - auto/marine, household, industrial, etc.
http://www.mcmaster.com/#electrical-controls/=j6ss2f
blitzoid is offline
post #7 of 11 (permalink) Old 09-11-2012, 10:36 PM
Has anyone found a switch that will fit perfectly in there? I didn't understand the gluing the switch part, I was hoping for a simple push button or a flat rocker switch. I need one to put the purple footwell lights in the gfs car and I may need one down the road for an amp kill switch or something along those lines.
jeffdroid is offline
post #8 of 11 (permalink) Old 09-12-2012, 06:05 PM
1) remove current switch blank
2) Drill hole install hole in the center of the blank, sized to match the switch you get
3) Use glue (or just the mounting ring on the switch) to complete the installation.
try these: http://store.mp3car.com/category_s/110.htm
blitzoid is offline
post #9 of 11 (permalink) Old 09-12-2012, 09:42 PM
Ahh I was thinking you meant to have a push button switch like our traction control switch. Looks like I would have to use a toggle switch rather than a rocker then
post #10 of 11 (permalink) Old 09-21-2012, 09:30 AM Thread Starter
Wiring
What is the best way to get the wires from my new LEDs in the grill to inside the cabin so I can connect my switch? I have been looking for the existing wires and where they go but I cant see under or around all the shrouding.
Stuart is offline
LinkBack to this Thread: http://www.mazda3forums.com/673-2010-2013-exterior-lighting/395406-toggle-switches-mazda-3-2011-dash.html
2010-2013 Exterior Lighting [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-30-2015 11:35 AM
