Fog glare bandage removal help needed - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 2 (permalink) Old 05-11-2011, 01:02 PM Thread Starter
I'm looking into removing the glare bandages inside the fog housings when I install my HID's. Has anyone done this before and if so; how difficult is it? I see that there is only one screw holding it on but its from the inside and looks like you have to take the housing apart to get it out. just got a DDM 6000k HID set and i'm wondering if its worth the trouble of removing them. Any info is appreciated.
sotrbox is offline
post #2 of 2 (permalink) Old 08-10-2011, 02:40 PM
GrifN's Avatar
Re: Fog glare bandage removal help needed
If you haven't found the answer to this, from what I've read/heard, the fog housing is molded/sealed plastic (like the taillights, NOT like the headlights), so you can't bake apart. Ergo, taking apart the fogs would involve cutting them open.
HOWEVER, I also read somewhere on here about a guy bending/breaking some tabs off in the fog housing that had something to do with glare or something, if that might be what you are referring to...
My
Build Thread
should never be forgotten.
GrifN is offline
LinkBack to this Thread: http://www.mazda3forums.com/673-2010-2013-exterior-lighting/382866-fog-glare-bandage-removal-help-needed.html
2010-2013 Exterior Lighting [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 11-07-2017 04:41 AM
